-   -   Threaded Inserts (http://forums.pelicanparts.com/porsche-911-technical-forum/512956-threaded-inserts.html)
whiskyb 11-24-2009 02:51 PM
Threaded Inserts
I am in the process of painting my car. Tomorrow I will spray my first coats of epoxy primer. Before doing so I need to drill some hole for threaded inserts. They are 6mm thread but i do not know what size hole they take. I am not even sure if they are all the same but would like to drill and then epoxy for the best corrosion protection
Anybody have any idea on hole size.
rick-l 11-24-2009 02:55 PM
:confused::confused:
Mo_Gearhead 11-24-2009 03:03 PM
1. Purchase inserts
2. Measure OD
3. Drill
...you're welcome?
sc_rufctr 11-24-2009 03:04 PM
Post some pics of the inserts and tool used to set them.
If they're the ones I'm thinking of the hole is about 8 to 9mm but it would be better if you measured them with a dial calliper.
What are you going to secure with them?
More info so we can help!
dad911 11-24-2009 03:15 PM
McMaster-Carr
whiskyb 11-24-2009 06:23 PM
Thanks, i found what I was looking for here http://www.stanleyind.com/Downloads/AuthorizedDist/Marson_Threaded_Inserts.pdf on page 4.
