Santa Clarita, Ca.
Question Need help with these electrical terms
Looking at at 73 wiring chart and it has the following descriptions;
#6 Ignition Transformer
#9 High Tension Ignition Unit
#13 Control Pressure regulating valve with warm up compensation
I think I know what these are but can somebody please confirm for me?
Old 11-24-2009, 06:28 PM
HarryD's Avatar
Good to see you looking at the diagrams
We call it the coil
We call it the CDI unit
We call it the Warm up regulator.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-24-2009, 06:56 PM
Santa Clarita, Ca.
Thanks Harry, that's what I thought. I'm having to build a custom harness and wanted to make sure I had the correct routings.
Old 11-24-2009, 09:10 PM
HarryD's Avatar
Glad to help.
Do yourself and the next guy a favor and use the factory colors for the wires. That way you can use the factory wiring diagrams to troubleshoot your electrics in the future.
Also, if you go with a homemade wiring loom, most pros (if you ever need the help) will either refuse to work on it or charge you an arm and a leg because they can't use the factory drawings.
Harry
2020 MB E350 4Matic
Old 11-24-2009, 09:13 PM
