Certified Porsche Nut
Wevo engine mounts and factory transmission mounts
I really really need to replace my engine mounts. I can feel the engine move!
Looking at the Pelican catalog I have a few choices on the engine mounts, the Wevo ones look like the way to go. On the transmission mounts I only have one choice (early square mounts) - factory standard. Do you think there is any side effect or negative to mixing the two? |
Loose nut bhind the wheel
I run that setup on my Targa. No problems. I will, over the winter, order up the WEVO kit to upgrade my 901 tranny mount to their mounts. It requires some cutting and welding and of course powdercoating. The only reason for the uograde is my tranny mounts are vintage 1970 and bushings are not replaceable like the 915.
Ed 1970 911S Targa 2.7RS MFI dual plug 10.5:1 1974 260Z SCCA ITS 1998 M3 |
Are the 901 tranny mounts not replaceable?
Pelican sells part 902-305-492-00-OEM that made me think it is replaceable. |
Almost Banned Once
They're not replaceable. This is worth a look...
Welcome to Windrush Evolutions - WEVO - Porsche Products
- Peter |
I would not worry about mixing the two. Be aware that the Wevos will introduce quite a bit more noise and vibration. Perfectly acceptable in some circumstances, not so much in others.
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
AutoBahned
if a problem, then get the softer Wevo mounts - different color plastic in them
Ferdinand Magazine
Great products, designed and build by a compatriot of yours. Go for it!
Sheriff at www.impactbumpers.com Brand support at classicretrofit.com/tuthillporsche.com 1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles |
Quantum Mechanic
or you can refurb the mount
The Wevo mounts look very nice - but they are not compatible with the early mounts. You may be able to mix and match a later mount into your car.
What I did, with very good results, was to remove the mount from the car, and use your power drill to swiss cheese the worn out rubber bushings in the mount. Punch them out and powder-coat it, and then order the polygraphite bushings from our host and put them in. On my SC I run the polygraphite bushings on the trans, and factory "sport" mounts on the rear. This combination gives good shifting and minimal increase in harshness / vibration.
Mark Petry Bainbridge Island, WA 81 SC |
AutoBahned
yes, to use the 915 Wevo mounts, he will need to make an adapter for the 915 trans. Xbar to fit his tranny
Wevo also refurbs the 901/911 Xbars - not sure what sort of mounts they put on them |
Adelaide901
I had Buiks in Adelaide press out my old trans mounts and press in new Wevo's. I am running the blue mounts on both engine and trans and they are a little harsh. I'd go softer if I did it again... Cheers
'74 RS 3.0 Replica Porsche 968 Clubsport SOLD '70 911E Bahia Red SOLD '71 911 S/T Replica 2.3 Twin plug BEAST SOLD
Anybody running the wevo black pillows all around ,hows the noise?
Almost Banned Once
A friend is running them and they are quieter than the standard Blues. I didn't drive the car but felt good from the passenger seat.
- Peter |
I'm running WEVO's with the softer black pillows for both engine and transmission mounts. Works great. Minor increase in noise but not a problem at all. I suspect the old mounts were so loose that this is way it is really supposed to be. Also, these mounts tighten things up so that my shifting is much smoother and more predictable.
Ralph
82 911SC Targa with Megasquirt EFI |
That's what I'm running. No problems.
WEVO said I could send in my tranny mount and they would install WEVO mounts on it, but I didn't want the extra vibration coming through the chassis.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
