I need help finding the tachometer wire in the engine compertment.
I have a 1976 911S. Before I bought the car it had been converted to Weber 40 Ida 3cs from fuel injection. Some of the wiring has been mest with. Everything works accept the tachometer. I can not seem to find the wire for the tachometer. If I new which wire or the color of the wire would be helpfull. Any help would be great. Thanks.
Old 11-26-2009, 10:52 PM
Turboo934's Avatar
Black/ Purple tracer .
Old 11-27-2009, 12:29 AM
grateful user
don gilbert's Avatar
black w/purple tracer on left side off enging compartment, on a 76 you can hook it up to the + side of your coil and it will work fine.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 11-27-2009, 05:30 AM
