Ruby911
ruby911's Avatar
Ticking Noise, not Rythmic
I am picking up a ticking noise when driving my '84 Carrera that I cant pinpoint. The tick does not have a consistent rythm to it and does not do it at idle. It reminds me of the valve rattle you get in an american V8 when you run low octane gas in it. It seems to do it under moderate accleeration or constant RPMs while cruisng at about 3500 RPMs.
Any ideas?
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 12-16-2009, 05:02 PM
christojen's Avatar
I would get one of those auto stethoscpes and try to pinpoint the noise. Otherwise your description sounds a bit like pinging which is incorrect timing.
CJ
Old 12-17-2009, 02:00 AM
muck-raker
kidrock's Avatar
+1, I agree it sounds like pinging. Can possibly be fixed by using a higher octane fuel.
Not to steal the thread, but if the pinging is caused by timing, what can you do to eliminate pinging if you have a DME-equipped car?
Also, can't pinging be caused by improper air/fuel mixture (lean condition)?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 12-17-2009, 04:49 AM
Ruby911
ruby911's Avatar
I have always run the highest octane fuel available in GA and the ticking has only come on recently, so I doubt that is it. Could the ticking noise be an exhaust leak? I would think an exhaust leak would happen at all rpms and have a rythm to the ticking.
1965 356C Outlaw
RGruppe #577
Old 12-17-2009, 04:59 AM
I recently had a problem with my 1988 Carrera 3.2 which was traced back to sparkplugs (specifically #6) which were improperly installed by PO to have backed up until #6 was out of the socket! I was running on 5 cylinders. When I put in new sparkplugs and did a valve adjustment check everything runs like they're suppose to.
Old 12-17-2009, 05:21 AM
T77911S's Avatar
if it is pinging or spark knock, then timing or something making it go lean. air leak?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-17-2009, 05:59 AM
BReyes's Avatar
Mileage? Visual inspection ok? Ignition tune up ruled out? When was last valve adjustment? How are the valve train components, tensioner, ramps, chains?
Regards,
Bernard
Old 12-17-2009, 06:22 AM
Designer King
Paulporsche's Avatar
Are you sure it's from the engine? How about a stone in the tire tread?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 12-17-2009, 09:34 AM
Ruby911
ruby911's Avatar
I am doing valves this weeked and am curious if I will uncover anything 'interesting'. We'll see what happens...
I would think stone in the tire would be very rythmic.
1965 356C Outlaw
RGruppe #577
Old 12-18-2009, 06:55 PM
Detached Member
Hugh R's Avatar
Plug wires?
Hugh
Old 12-18-2009, 07:08 PM
is it possible a rocker adjustment bolt has backed off a bit?
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 12-19-2009, 03:12 AM
jderrick's Avatar
Perhaps the following link can point you in the right direction.
Ticking sound from dashboard
Regards,
John
Old 12-19-2009, 07:23 AM
Ruby911
ruby911's Avatar
definately not comnig from the dash, it is from the engine bay. Valves are being adjusted right now. The idea of a head stud fallibng out when the valve covers are removed is a notion that keeps entering my brain - I keep pushing that notion back - dont want to think about that right now....
1965 356C Outlaw
RGruppe #577
Old 12-20-2009, 05:37 AM
Almost Banned Once
sc_rufctr's Avatar
Based on you initial description I suspect a broken valve spring.
- Peter
Old 12-20-2009, 05:43 AM
Ruby911
ruby911's Avatar
thanks all for the feedback, fingers are crossed.
1965 356C Outlaw
RGruppe #577
Old 12-20-2009, 05:51 AM
E Sully's Avatar
85 911 - Strange Noise
Check this link. Throttle body deicing valve by the oil tank can cause a rattle when it is bad.
Old 12-20-2009, 08:18 AM
Ruby911
ruby911's Avatar
valves adjusted and problem solved. Thanks all. Damn she is running good!
Old 12-21-2009, 04:49 AM
