ncseahawk's Avatar
Rear Tail Light Assembly Rebuild
So it started with simply wanting to change out the rubber gasket around the assembly but...
It was gross in there and winter is here anyway. Might as well give this simple project a start.
After getting this backing plate off the wires and interior of the assembly revealed about 1 pound of pebbles and sand.
Wires were slathered in the detritus as well.
So I marked each set.
Next was to ensure the near ends were marked.
Tonite I will work on the gunk and rust on the backing plate and assembly. Tomorrow I will work on re-chroming the interior of the assembly. Does anyone have any experience with the Duplicolor Chrome?
Also, I am thinking about drilling some holes for weight. You would not beleive how heavy this assembly is.
1985 Carrera Under Modification (SOLD)
2003 Carrera 4S
Old 11-27-2009, 02:59 PM
MrPerkles's Avatar
Send a message via MSN to MrPerkles
those rear housings are silly heavy ,look foward to your idea on lightening them.I keep thinking about doing something with mine
www.facebook.com/pages/Bournville-Frameworks
Old 11-27-2009, 03:10 PM
ShakinJoe's Avatar
Rob,
I have not used the duplicolor but have used "chrome" model paint on some items and man it is chrome like. Good luck!!
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 11-27-2009, 03:30 PM
I wen to fiberglass RS taillights. They weigh nothing. Well,very little...
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 11-27-2009, 03:42 PM
MBAtarga's Avatar
How many pebbles and how much sand do you think will get in there once you start ADDING holes to what is supposed to be a sealed assembly?
Mark
'83 SC Targa - since 5/5/2001
Old 11-27-2009, 04:23 PM
ShakinJoe's Avatar
+1 here Rob. You will not believe will get in there if you add holes. I have one where the drain tube popped out and it got FILLED with sand and pebbles.
Old 11-27-2009, 04:37 PM
I used Duplicolor chrome. Certainly looked better than when I took them off the car I also painted the outside in POR-15 gloss grey which I hope will be an easier surface to keep clean.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 11-27-2009, 05:34 PM
AutoBahned
RWebb's Avatar
yup, you want FG housings - too bad nobody in the US makes them for the stock lenses.
DP in Germany made some like that and they are mentioned in an article in this month's Excellence - but I've never seen them here.
Old 11-27-2009, 08:17 PM
ncseahawk's Avatar
Sunday Update
Did not get a lot done... or at least not what I was hoping, instead.
Fixed the rear backing plate and painted.
Also re-chromed the interior of the light assembly. Dupli-color Chrome anyway. I think it will be fine. It appeared the original finish was also a painted on chrome finish.
Cleaned and buffed the small plastic reflecting window that goes inside the apparatus. Also had the time to finish up a drivers side block off plate that I had been restoring. That is another project though.
So now two questions or input opportunities.
1. There are already multiple holes in the apparatus, both inside where the bulbs are and in the backing plate. I have found a shrink wrapping poly ethylene that I am considering. Will this be a fire hazard? I may just have to stick with my 7 pound assemblies.
2. Is a glue or adhesive used to bond the rubber like seal around the assembly? What kind?
that is all for this weekend.
MTF
2003 Carrera 4S
Old 11-29-2009, 03:27 PM
Weekend Mechanic
vulcan300's Avatar
In answer to question 2, I'd guess that Wurth contact cement or something similar would help attach the seals to the housing.
For question 1, sealing the holes from the outside with a sheet of clear lexan (sprayed black) might do the trick, and should weigh much less than the metal you'll be removing. The heat from the bulbs won't be high enough to melt it.
J
86 911 Carrera Targa
Old 11-29-2009, 09:22 PM
