I need a heater blower motor AGAIN !
I replaced the heater blower motor awyile ago with a used one, and now, it too, is making big horrible noises. Do I get that motor fixed? Or replace with just any motor? Or try used again? I don't like cold.
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
I can spell awhile, I just can't type fast
The $22 solution:
Carrera replacement heater blower (long) edit: oooops. just noticed you had an SC. Try this: SC Blower Motor Brushes?
Jim 1987 Carrera 2002 BMW 525ti 1997 Buell Cyclone cafe project 1998 Buell S1W: "Angriest motorcycle I've ever ridden." Last edited by Dueller; 12-01-2009 at 11:07 AM.. |
thanks, but not brushes, it's a bigger noise than that. It's like bearings/bushings
Pelican Parts - Product Information: 911-624-151-02-PH)
Matt Kellett 87 Carrera Coupe - Marine Blue 60 MGA - Chariot Red 66 Jaguar MKII - Sherwood Green 09 VW GTI - Candy White |
Our host sells just the motor alone for the rear blower. You can easily replace it in its housing. I did it about a year ago in my '87. I think it was about $120. If you go that route you have to attach the leads to the connector. Make sure you get the polarity correct. It will blow air in the right driection with either polarity but air flow will be much higher with the correct polarity.
Chuck '96 993 C2 coupe '87 Carrera coupe - gone but not forgotten many lesser vehicles |
That's the one.
Did you try a little oil / grease? I have taken my fresh air blower and rear heater apart recently and shot them with oil and have had great (if only temporary) success.
Larry |
Still looking for a rear blower motor? I have what appears to be a NOS unit (or at least hardly used) that has been on my garage shelf for awhile. It's the complete motor/housing unit. Tested and works great! Will sell cheap!
i will send a PM
