-   -   Better to replace or rebuild my 915? (http://forums.pelicanparts.com/porsche-911-technical-forum/514046-better-replace-rebuild-my-915-a.html)
DannyBNH 12-01-2009 09:38 AM
My 79 SC isn't quite stock.. It's got a 77 915 tranny with an 87 3.2. The transmission is starting to getting a little termpermental in a few gears and it probably would be a good winter project to rebuild it... Luckily I know some people with the expertise who've done it quite a few times that I could call on.
I've seen on the classifieds board some 915's for between $1000 - $1500 that have been fixed where needed and am wondering is it better to
a) Just pull out my 915 and fix all the syncro's & whatever else it might need?
or
b) Buy a more up to date 915 that's been rebuilt?
Are there any advantages doing one or the other?
Dan
sjf911 12-01-2009 09:46 AM
Your 915 will already have the bell housing modifications for the 3.2 flywheel sensors so if you trade out you will need to get a 3.2 915, one already modified for a 3.2, or modify the new unit. OTOH, rebuilding your 915 is a great educational project and leaves you with a unit that you know what is inside.
Peter Zimmermann 12-01-2009 09:59 AM
Here's a start: http://porsche.wikidot.com/forum:start Click on "915."
It's always a good idea to start with a "known" entity. To buy a "Repaired/rebuilt" 915, for $1500, can be a costly mistake. After you do some reading you'll have a better idea what to do.
http://forums.rennlist.com/rennforums/911-forum/397133-it-cost-how-much.html?highlight=Cost+MUCH%3F
john walker's workshop 12-01-2009 10:06 AM
who knows what was done on an unknown "rebuild/repair". plug it in and find out? you're better off doing yours.
dshepp806 12-01-2009 03:44 PM
+1.
Best,
