Better to replace or rebuild my 915?
My 79 SC isn't quite stock.. It's got a 77 915 tranny with an 87 3.2. The transmission is starting to getting a little termpermental in a few gears and it probably would be a good winter project to rebuild it... Luckily I know some people with the expertise who've done it quite a few times that I could call on.
I've seen on the classifieds board some 915's for between $1000 - $1500 that have been fixed where needed and am wondering is it better to a) Just pull out my 915 and fix all the syncro's & whatever else it might need? or b) Buy a more up to date 915 that's been rebuilt? Are there any advantages doing one or the other? Thanks Dan
1979 Porsche 911 Black on Black widebody 3.2 - SOLD 2015 Jeep Wrangler Sport Unlimited - White 1984 Porsche 928s Black on Black - SOLD |
Your 915 will already have the bell housing modifications for the 3.2 flywheel sensors so if you trade out you will need to get a 3.2 915, one already modified for a 3.2, or modify the new unit. OTOH, rebuilding your 915 is a great educational project and leaves you with a unit that you know what is inside.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Here's a start: http://porsche.wikidot.com/forum:start Click on "915."
It's always a good idea to start with a "known" entity. To buy a "Repaired/rebuilt" 915, for $1500, can be a costly mistake. After you do some reading you'll have a better idea what to do. http://forums.rennlist.com/rennforums/911-forum/397133-it-cost-how-much.html?highlight=Cost+MUCH%3F
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 12-01-2009 at 10:05 AM.. |
who knows what was done on an unknown "rebuild/repair". plug it in and find out? you're better off doing yours.
Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
