-   -   Help Identifying gearbox (http://forums.pelicanparts.com/porsche-911-technical-forum/514207-help-identifying-gearbox.html)
Johnny B 12-02-2009 04:18 AM
Hello Guys,
Am I correct in thinking this is a G50 from a 1987 911 3.2 Carrera
no is 950301102 3R and the engine no he gave me was 63H***** so motor is definately a 3.2 1986/87 I think
http://forums.pelicanparts.com/uploa...1259756278.jpg
sc_rufctr 12-02-2009 04:27 AM
Sounds correct.
Why are you worried about it? Get it in your car already!
Matt Monson 12-02-2009 06:24 AM
What you have posted there is a casting number off of one of the cases. If you flip it over and look at the rib on the bottom side there should be a serial number stamped on it starting with G50. It is a G50/01 from a 3.2l Carrera based on the picture, but if you post the complete serial number we can tell you if it's an LSD unit or not.
Johnny B 12-04-2009 04:43 AM
thanks for info much appreciated.
It has 50/00 stamped on the underneath, below is another photo how does one tell if it has lsd or not?
http://forums.pelicanparts.com/uploa...1259930525.jpg
http://forums.pelicanparts.com/uploa...1259930617.jpg
Matt Monson 12-04-2009 06:57 AM
What follows that g50/00 next? That's not the whole number.
You can also spin a flange and see what direction the opposite one turns to see if there's an LSD in there. An LSD will have the opposing flange spinning the same direction.
Johnny B 12-04-2009 07:13 AM
thanks ,looks like 73H after that and then I need to clean it up a bit to see the balance of the numbers clearly
