Bungled up flywheel sensor connector on '84 911
I'm a long time lurker, first time poster...
I've just completed replacing the reference sensor (both the BG and the DG marked sensors) on my 1984 911, thanks to the many of you who have diagnosed these and guided the process with all the posts on this here. I did use the BMW part number the sensor instead of the Porsche part number and basically got both sensors for the price of 1, thanks the the tip! However, somehow when I reconnected the sensor plugs in the engine compartment, the center post snagged the female side and bent it back inside the plastic socket. It's pushed so far back in there that I'm sure it's not making good contact. I tried to straighten it out with a small blade screw driver and snapped it together and got the car started, but a test drive around the neighborhood had it cut out and die and not restart. I opened the hood and pushed on the connector and the car restarted and I was able to get it home, but I'm at a loss as to how to repair my screw up. The plastic plug is solid plastic and I can't pull the female metal connector out of the center position (even though I can see where the wire crimps inside to the metal female clip). Is this plug end a replaceable part? I guess the other possibility is that my intermittent cut out problem wasn't the reference sensor after all, but I still need to get this plug fixed properly to rule it out. Thanks, Bob H. Columbus, OH |
If I were you, I cut both ends, use a 2 wire connector from Molex, and be done.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Are they Junior Timer connectors?
VWvortex Forums: "Junior Timer" electrical connectors on mk1 harnesses? Available from Digikey.
Rick 88 Cab |
Thanks. |
BobH99,
Porsche repair parts are available. Not sure exactly what your end connector looks like...but these are the Junior Timer style parts listed. Try these, They are listed under the '87 to '89 911's in the PET program. Spring Connector 999 652 456 22 OR Grey connector housing 022 906 231 A use with Spring clip N 903 353 03 Good luck, you're not the only one to have messed up an end connector ![]() Cooper
Cooper's Classy Car Care Providing Clear Bra installation, Paint touch-up, Detailing PCA/OCR since 1997 '81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter |
Thanks for the tip Cooper. I ordered the Spring Connector 999 652 456 22 from our host and got it installed this past weekend, it was an exact replacement. I ordered three of them since they were only a buck each just incase I screwed it up again. Luck was on my side so now I have two spare! I drove the car for several hours on Sunday with no cut-out issues, looks like the problem is solved.
Thanks again. Quote:
Glad it worked out for you. Thanks for letting me know!
Cooper |
Way to go Bob! - And Welcome!
Now that you have that sorted - post a pic. ;-)
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Photo 2
I've since put one of those scoop inserts in the side marker light hole in the bumper.
muck-raker
very nice looking ride. IMHO, a headlight upgrade and front lip will add the perfect finishing touches...just my $0.02 cents.
BTW, is that scoop producing any measurable difference in cooling?
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
As for the scoop; I had been running without the side marker light during all the summer track events anyway and just wanted it to clean up the look a bit. I believe it makes a difference in the heat of the summer, although I don't have any data to back it up. Last edited by BobH99; 12-04-2009 at 11:15 AM.. |
| Tags |
| flywheel sensor , ignition problem , reference sensor |
