I got it off a '70 911T tear-down.
It was at the back of the engine at the cover plates. Want to sell it, but can't say what it is or for. heeeelp me pls. RS
Oil dribbler for want of a better word. The bottom of the air box has rubber hose that collects oil from whatever source and sends it out to this item. You might want to keep it.
Bill '72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride. |
Hey Zot, thanks for reply. I may want to keep it?...why? It wouldn't be anything I'd need for an '81 SC engine? or yes? RS
It was used up to SC but after that the oil tank system was sealed and all vapors went to the throttle body. But if there is a tap on the bottom of the air box thats opened you might just run a hose to the piece you have to keep any residue off the top of the engine.
Bruce |
Where exactly is this oil supposed be seeping from to this oil catch pc? Why would there be any oil at all at the air box...enligten me.
Oh.. and the '70 it came from...or at least I think it came from, had Zeniths on it. thx RS Last edited by relayswitcher; 11-08-2009 at 11:30 AM.. |
I was going to reply earlier, but I didn't think a 70 with carbs would have one of these. It looks like someone capped it off.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
So then the rubber piece is the 'cap off' someone did? Flat6 said this was used "up to" the SC engines. And why would they design it to drip onto an exhaust...that causes smoke...my friend likes t say that "one single drop of oil will take 10 minutes to burn off"and.....smoke.
Anyone have a picture of this thing installed on a motor? |
Ubi bene ibi patria
I too have a similar part from a 1970T & would also like to see a picture of it properly installed. I must admit it was one of those things I forgot to record exactly where it came from during engine removal & dis-assembly.
Thanks & Cheers JB |
Here it is on my 73.5 CIS. The black rubber acts as a valve so air isn't drawn into the air box.
heiliges blechle!
My Aprilia has what I believe to be a similar "feature". It is a dry-sump engine and crankcase vapors build up in the airbox over time - especially at high RPMs and very especially if you overfill the oil and spend time running near redline. It has a clear tube hanging down from the airbox, plugged so the oil doesn't drip out or dirty air go back up. I suppose the thing is clear so you can see how much oil has collected and drain it if necessary.
'84 M491 '07 Silverado '75 Suzuki GT550 2-stroke triple '02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train |
the black "cap" has a slit at the bottom as a drain,
strategically aimed at the heat exchanger to get that distinctive aroma.
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
