RETIRED
Porsche 911 SC gas sender wiring schematic needed
I am returning my SC gas gauge to stock sender and gauge. I need a wiring diagram fro the sender that goes into the tank. Any got a diagram? Color coded.....
TIA
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
ROW '78 911 Targa
Sounds like you want the pin locations with the correct wire colors for the tank sender unit connector?
I have it in my book at home. Post it up later for you. Brown green and black are the wires run directly from sender to gauge. IIRC, Brown on lower left at entry point of connector. Green and brown up top (furthest from cable entry point) but can't recall which one on which side right now. Brown is ground, green is level, black is for low fuel lamp.
RETIRED
Yes, please.....
ROW '78 911 Targa
Standard 4 pole square connector with female terminals. (3 used)
Clockwise from bottom(cable entry) with lid removed as a viewing perspective. Left lower is brown, then Green, then Black, blank on lower right of cable entry. Sorry it took so long, I actually typed it all up on my phone 4-5 hours ago but got distracted and didn't hit reply....
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 09-23-2016 at 12:56 AM.. |
RETIRED
Ah, a word problem...thanks. I'm gonna draw it out and then work on it. More of a visual kinda guy.
Author of "101 Projects"
For clarity...
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
