wondering idle on a 1982 911SC
Does anyone have a permenent solution to a wondering idle (from about 800-1400rpm) on the 3.0 with the CIS injection system?
Old 12-09-2009, 08:52 AM
Dixie Region R Gruppe
w21055's Avatar
Could be a number of things. It seems like the winter time allows it to show its face. Did you check for vacuum leaks? Does it only do it while it is cold?
I would do a search for CIS trouble shooting on here and you will probably see a few ideas.
Phillip
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 12-09-2009, 08:56 AM
Somatic Negative Optimist
Gunter's Avatar
Question
It's a wonder that some engines even run.
Wonder what it could be?
Doesn't sound like hunting with that much difference in RPM.
It's an '83 but more maintenance history is needed to give an opinion.
Tune-up? Distributor ever cleaned/oiled/serviced? Throttle linkage jammed by the clutch cable near the bell crank? When does the RPM change? During cold-start? At a red light? When doing what?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-09-2009, 10:45 AM
T77911S's Avatar
that would make for a serious rich condition. surprised it does not cut off if you give it gas and let the RPM's drop.
check fuse 18 for the dme relay
power to the WUR, 12v.
control pressure.
that order because of ease.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-09-2009, 11:09 AM
scottrx7tt's Avatar
I unplugged my o2 sensor on mine, and its rock solid 800rpms.
Old 12-09-2009, 11:30 AM
Gunter's Avatar
It's an SC and SC's have no DME.
Carreras have DME.
'83 SC's have a Lambda ECU under the pass seat and when it doesn't work, the engine runs very rough in idle but no resulting increase in RPM and no surging or hunting.
Old 12-09-2009, 12:09 PM
I wonder why it wanders?
SC should idle at steady 950 RPM, unless it's just been started cold.
Old 12-09-2009, 01:44 PM
vash's Avatar
check your air/fuel mixture.
poof! gone
Old 12-09-2009, 01:45 PM
grateful user
don gilbert's Avatar
when your 02 sensor craps out, the ecm goes to a fixed duty rate, and could result in to rich a mix on a warm engine
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 12-09-2009, 03:15 PM
Recreational Mechanic
Nickshu's Avatar
Disconnect your O2 sensor. Reset mixture to 3-3.5% CO measured at the tailpipe. Problem solved. Idle hunts b/c frequency valve is trying to play with fuel mixture to meet emissions demands of the O2 sensor. Disconnecting pegs the Frequency valve at fixed position, 55-60% open I think. Vacuum leaks, even small ones, can contribute to the frequency valve idle hunting.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 12-09-2009, 06:29 PM
Drive it like u stole it.
jonesb930's Avatar
I had a very similar issue on a 76 turbo motor years ago. It turned out to be the WUR. I used a gauge set to test system pressures at various points in the CIS system and narrowed it down. Order one from our host if you don't have one. They are invaluable in trouble shooting CIS.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 12-09-2009, 06:43 PM
