What's the difference between the 930 & 911 steering rack?
Is it just the input ratio?
Thanks, jp |
Does any one know the answer to this question I would also like to know.
Are the ratios the same? Is the 930 stronger in some way?
1978 race car scca GT2 1998 C2S sold 1996 C4S sold 1973 911 T restored with 2.7 RS running gear 1970 911 E Project |
The steering ratios are identical, the housings are slightly different to accomodate the 930's anti-dive suspension geometry...
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Steve,
So the 930 isn't stronger or have larger internal gears or anything? How difficult is it to rebuild the rack with quick ratio gears and is a quick ratio set up stronger, weaker, or the same as stock? And lastly do you regularly rebuild or install the Quick ratio gears?
