-   -   Engine and Chasis No. Check Please? (http://forums.pelicanparts.com/porsche-911-technical-forum/515351-engine-chasis-no-check-please.html)
mowen 12-08-2009 08:17 AM
Hello. Looking at car with following Chassis No (WPOZZZ99ZVS311760) and Engine No. (637854232). I have read about the chassis codes etc but how can I match Chassis to Engine No. Also want info on Engine Number ie is it Varioram version etc. Can I tell wheather the vehicle has the ABD system fitted from the engine number? Help??
ttweed 12-08-2009 08:55 AM
Are you in the USA or is this a ROW car? If the former, you might be able to call PCNA Customer Care at 1-800-porsche and ask them. If you are only looking at it and do not own the car, they may be reluctant to answer all your questions, but should be able to verify that engine and chassis number match.
TT
twistoffat 12-08-2009 09:17 AM
Are you referring to the 993 in Car and Classic magazine?
If so V certainly relates to a 1997 car
This Link should help. The V in the motor Nr is a 7 so 993īs (1997) indeed started with 637
http://www.elfer-gtr.de/Motorvarianten.htm
Calling porsche would still be the best solution
mowen 12-10-2009 11:35 AM
Not sure if its the one in classic car, thats not where I have seen it.
Thanks for your help.
