jpahemi's Avatar
What's the difference between the 930 & 911 steering rack?
Is it just the input ratio?
Thanks,
jp
Old 01-02-2009, 06:24 PM
jwerion's Avatar
Does any one know the answer to this question I would also like to know.
Are the ratios the same?
Is the 930 stronger in some way?
1978 race car scca GT2
1998 C2S sold
1996 C4S sold
1973 911 T restored with 2.7 RS running gear
1970 911 E Project
Old 12-10-2009, 12:11 PM
The steering ratios are identical, the housings are slightly different to accomodate the 930's anti-dive suspension geometry...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-10-2009, 12:35 PM
jwerion's Avatar
Steve,
So the 930 isn't stronger or have larger internal gears or anything?
How difficult is it to rebuild the rack with quick ratio gears and is a quick ratio set up stronger, weaker, or the same as stock?
And lastly do you regularly rebuild or install the Quick ratio gears?
1998 C2S sold
1996 C4S sold
1970 911 E Project
Old 12-10-2009, 12:57 PM
