Jupiter 911
bklyn's Avatar
volume air flow unit
Gents, can someone advise or show the web site that shows how to adjust the vein inside the air flow unit. I see the Bentley shows how to check and replace the unit as a whole but I remember someone posted how to re-track the vein. Thanks
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 12-08-2009, 04:10 PM
Steve W's Avatar
You don't want to adjust the clock spring tension - leave that alone. But you can check and renew the meter by repositioning the wiper arm north to sweep on a new arc.
Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk
http://www.clarks-garage.com/pdf-manual/elect-22.pdf
Old 12-08-2009, 04:37 PM
Jupiter 911
bklyn's Avatar
Thanks Steve, this was the site I was looking for.
Old 12-08-2009, 04:46 PM
Jupiter 911
bklyn's Avatar
One more question, I guess use a utility knife to open the plastic cover and reseal it using 3m weather stripping adhesive or do you suggest something else?
Old 12-08-2009, 05:11 PM
Steve W's Avatar
That should be fine, but you'll likely need something stronger like a flat screwdriver to pry up the cover. You can use some type of clear or black silicone to glue the cover back on.
Old 12-08-2009, 05:40 PM
T77911S's Avatar
i think i would use RTV, the real stuff, not the crap you get at lowes. the 3M stuff may be way to hard to get off next time
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-09-2009, 05:20 AM
Jupiter 911
bklyn's Avatar
Thanks, and I have plenty of the RTV-red.
Old 12-09-2009, 08:14 AM
