911R Flip over rear lid hinges spacing?
How far apart to space 911R flip over rear lid hinges?
Thanks.
Old 09-11-2009, 01:36 PM
rw7810's Avatar
Mine are about 19.25 inches center to center
Robert Williams
70' 911T
Old 09-12-2009, 07:22 AM
Originally Posted by Wayne at Pelican Parts View Post
I'll be at Tony Callas' shop on Monday. He has #1 there (BP car). I can measure then, if I can remember all the way to Monday.
-Wayne
Thanks, I'd like to get it right.
Old 09-13-2009, 11:11 AM
Owner, Callas Rennsport
TCallas's Avatar
I currently have two factory 911R's at the shop. Did you get the information you needed?
Phone: 310-370-7038
Located in the Greater Los Angeles Area
http://www.callasrennsport.com
Old 12-05-2009, 08:22 AM
gestalt1's Avatar
so, are they 19.25" on center?
thanks
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 12-05-2009, 11:42 AM
I never got a definitive answer.
As it happens I've not done it yet either, so good timing!
Running a 95 993 motor in an SC....
Old 12-05-2009, 12:12 PM
TCallas's Avatar
I just measured the two cars I have and here are the results:
#001 911R 19 3/4" (50.00mm)
#019 911R 20 7/8" (53.25mm)
I would be willing to bet money that the 001 car is correct at 50mm. The Germans wouldn't have done it any other way. Hope this helps.
Tony Callas
Phone: 310-370-7038
Old 12-07-2009, 10:27 AM
Mr9146's Avatar
Exact spacing is subjective which is why there are two different numbers from Tony.
The hinges need to be far enough apart to safely support the lid, but not so far that they bind on opening and closing ... this is because of the rounded shape of the body.
This distance may change due to the shape of the lid being used - the shape of fiberglass layups will differ slightly from lid to lid.
None of these parts were "production" pieces so slight differences will net a slightly different result.
Old 12-07-2009, 01:01 PM
gestalt1's Avatar
so, i guess any spacing is good as long as it is a metric measurement
BMW 128i
73 rsr clone - sold
Old 12-07-2009, 04:26 PM
Mr9146's Avatar
A more accurate statement might be, "Any spacing is good as long as the hinges work properly and don't bind."
Any metric measurement can be converted to SAE and vice versa... :-)
Good luck. Measure 5 times...drill only once.
Old 12-07-2009, 04:48 PM
Almost Banned Once
sc_rufctr's Avatar
Just for reference here are some photos...
I'm not sure if this one is an authentic 911R. It resides in Japan.
ST flares... Both of these are closer than the blue car.
- Peter
Old 12-07-2009, 05:17 PM
Are the correct hinges on the blue Japanese car ?
Tony I think that you meant 500mm or 50cm.
Old 12-07-2009, 06:24 PM
Registered Misfit
Mark Morrissey's Avatar
Here is the back end of 911R #20
The hinges on the Japanese car are not correct but it looks like a very cool car. Anymore photos?
Cheers,
Mark
Instagram: mark0morrissey
Website: www.markmorrissey.org
911 hotrod -- 3.2L, short stroke, twin-plug. Elephant Racing Turbo brakes, Tarrett suspension. Lightened, abused with love
Old 12-07-2009, 06:36 PM
Mr9146's Avatar
Here are some photos of my old blue car with a set of R hinges installed. The hinges were repopped by Zeke and, when installed, needed a spacer to make the hood fit perfectly. Other users of Zeke's hinges did not need the spacer.
Also, with hinges I sourced from other places, some needed spacers and some didn't. It's a hit and miss thing with non-production parts.
Enjoy!
Old 12-07-2009, 07:16 PM
a.k.a. G-man
Geronimo '74's Avatar
I'm pretty sure he did.
Old 12-07-2009, 09:55 PM
Almost Banned Once
sc_rufctr's Avatar
Cheers,
Mark
I'll post all the pics I have in a new thread.
- Peter
Old 12-07-2009, 10:00 PM
Tony Callas
Thank you. I'll go with 50cm.
Originally Posted by Mr9146 View Post
Thanks, that is the style of hinge that I have.
Old 12-08-2009, 12:08 AM
TCallas's Avatar
I definitely meant CM (Centimeters), thank you. I have personally worked very close with the group at Weissach (Flacht) and know how they think so I would still bet that a German and especially at Porsche they wouldn’t just choose a different place on every car. I am pretty sure that there was standard and I would guess it was 50CM center to center. Tony Callas
Phone: 310-370-7038
Old 12-08-2009, 06:17 AM
ttweed's Avatar
I measured the hinge spacing on #11899002P (911R #2) when it was here at Symbolic Motors and the hinges were 19.5" center-center.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 12-09-2009, 01:29 PM
