vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Fuel filter line question
I am reinstalling my engine after too long on an engine stand and the upper connection for the fuel filter is not apparent. Can somebody help me figure out the connection to the top of the filter? It looks like it should be obvious (and it probably is) but does anybody have pics or a good description of where the line comes from?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 06-17-2012, 06:03 AM
pete3799's Avatar
One of the top fittings on the accumulator goes down and into the bottom of the filter.
Pete
79 911SC RoW
Old 06-17-2012, 06:34 AM
vesnyder's Avatar
It's the connection for #16 in the schematic - the one that shows no connection. Below is a pic that shows the connection I am looking for.
Vance
Old 06-17-2012, 07:11 AM
ROW '78 911 Targa
timmy2's Avatar
Should be a platic line with a curved metal end coming out from behind your cruise module?
It's the supply line to the back of the CIS. Near a "tee" Mounted to the #3 intake runner stud.
The tee lines go to return line to tank and bottom of accumulator.
May be the fitting lying just below the lower accumulator fitting to the right in your picture.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-17-2012, 09:14 AM
vesnyder's Avatar
Still cannot locate it! The fitting you see in the pic fits to the bottom of the accumulator. May need to go by the local Porsche shop and see if I can see if he has an SC he is working on.
Not sure you are saying that it is a line coming from behind the cruise control module or it comes from the #3 intake runner. Either case I do not see anything?
Vance
Old 06-17-2012, 07:45 PM
scotricker's Avatar
I think you are looking for this:
also, you can look at the diagram above, it is at the end of #13.
On mine, a 78 SC, it is a bendy hard plastic line that comes out from the back of the CIS. I just took mine all apart and the CIS is over on the bench. HTH
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 06-18-2012, 06:04 AM
ROW '78 911 Targa
timmy2's Avatar
That is the one you want.
On my '78 it runs from filter down behind intake 3 and then behind cis to the fuel distributor.
Old 06-18-2012, 07:45 AM
