-   -   Setting advance on an 83 SC: final word ? (http://forums.pelicanparts.com/porsche-911-technical-forum/515766-setting-advance-83-sc-final-word.html)
Deschodt 12-10-2009 11:59 AM
I've just reached the end of the internet (on this board anyway) about timing issues on an SC...
From what I gathered, there are 2 schools of thought, though not all that far apart in results, just different in *how* you get to the magic number... Correct me if I am wrong !
Everybody seems to agree that 25 BTDC at high RPM (the factory settings) is super conservative and set that way by porsche to account for 87 octane, higher engine compression in 83, and emissions crap.
Then there are 2 theories...
1) One recommends that I run essentially factory settings (5 BDTC, netting 25 at higher RPM, give or take a little), but that I leave the retard vacuum line off the distributor and plug it, thereby decreasing the excessive retardation at idle (an emission gimmick) that makes the engine run hot... you *can* run more total advance because this 25 degree setting is designed to be safe but that can only be determined by a pro "testing" your car on a dyno for detonation and backing off a few degrees... So, no hard and fast rule.
2) Others, including some fairly famous mechanics on this forum, generally recommend setting advance to 32-35 at high RPM and letting the idle fall where it may - generally higher: like 10 to 12 degrees. I did that 10K miles ago, I think I ended up at 32 - since I could hear it ping at 35D under WOT and backed it off a bit - and my idle was 10D BTDC with the retard line off - logically 20 degrees less than 5000 RPM which is the range of an SC distributor. My car ran well enough (it did not self destruct, at any rate) and importantly, it ran much cooler than before.
I can see where approch #1 is safer as you may not always hear pinging!
Since, as of last night I am back on factory settings (5D at idle, vac off) - and unfortunately running way hotter - I will simply disconnect and plug my retard line and see what happens. The car should run cooler at low RPM and be super safe at high RPMs. Tonight I'll measure high RPM advance with and without the advance vacuum, for giggles, because while I know that I have good retard vacuum, I never measured the advance vacuum (more debate there, some say there is zero vacuum at high RPM)....
If the car still runs too hot that way (and I suspect it might, but I'd be happy to be proven wrong), it'll be fairly obvious to me and I'll go back to the 30-32 degree settings which I've run for over a year with no *apparent* damage, and which netted me cooler temps.
At this point, knock on wood, she's got 185K miles and if she blows, she blows (doubtful since I put 15K miles last year with that same advanced timing)...Oh, I run 93 exclusively, obviously.
If someone sees something flagrantly wrong with the above, let me know before I blow up my engine !
psalt 12-10-2009 12:35 PM
Greg,
The specs for your engine are with both vacuum lines disconnected and plugged. The vacuum advance is a load based system, not rpm based like the mechanical advance. The vacuum advance will distort the timing measurement when you are blipping the throttle at rest by varying amounts each time. However in practice, the engine is under load at high rpm and the advance you want to focus on is solely the mechanical advance. In other words, if you leave the vacuum connected the actual advance under load, when the possibility of detonation exists, will be different. The amount of vacuum at WOT under load is very small, 1 or 2 inches, below the threshold of the vacuum advance, and if you can measure it accurately, it can tell you how restrictive the intake system is and how much can be gained by reducing the restriction. Have you looked at the spark plugs closely since you advanced the timing ?
mca 12-10-2009 12:40 PM
Thanks for taking the time to dig into this topic.
FWIW I have my retard line pulled and plugged - bumped up idle rpms accordingly. Mine is set to 5 BTDC at idle and reaches around 26 BTDC at 6000 rpms (actually reaches 26 at around 4000 but doesn't seem to increase after that).
If you don't mind, try to get a reading at 4000 rmps too. I'd like to know if you are also reaching full advance at this point.
Deschodt 12-10-2009 12:44 PM
Will do.. this has been a semi-mysterious topic for a long time now, it annoys me ;-)
Thank Paul for all your advice (as option #1) ;-)
no, I have not looked at my spark plugs, I didn't know you could tell anything from spark plugs since we run modern fuel ! What should I expect ? Or are you saying I should replace them on principle ?
psalt 12-10-2009 01:17 PM
Greg,
Personally, on a hemi headed engine like a 911 or a BMW M10, I run as much advance as I can on a road car with pump fuel. I am comfortable with my skills for setting the timing. Unfortunately, you can't send this skill in an email, and over advancing your timing can do damage. If you have a lighted magnifier and look closely at the insulator on a spark plug of an engine with high speed detonation, you will see tiny specs of aluminum. When you take the engine apart, you will see piston crown errosion as the source. Mild pinging is OK in a road car that spends 85% of the time below 35% load, but another issue on a track car. The main thing to understand is there are many variables and anyone who says they can give you the correct number over the phone is talking nonsense.
Deschodt 12-10-2009 01:33 PM
Funny you'd mention the 911 engine and the M10...
Here are mine:
http://www.erikaslist.com/pictures/both.jpg
Although the Bimmer's ignition is now all electro-optical and completely fire and forget ;-)
I wish there was an easy way to detect mild pinging, a device of some kind. Is there ? I will pull a plug and look...
Anyway I'm starting with your recommendation and will bump up advance slowly if temps remain higher than they used to be ;-) I may piss off my neighbors tonight, 6000 rpm on a 911 is loud ! Thanks !
psalt 12-10-2009 02:13 PM
Greg,
The M10 is a 54 degree VIA hemi, very similar to the 911, but with much better cooling. What kind of total advance are you running ? I have several 2002's and the stock distributors run out to +40 BTDC, and add vacuum advance on top of that.
The best instrument for measuring spark knock is a pressure sensor in a special spark plug, but there is no consumer version. Piezoelectric knock sensors are next, but they usually have to be tuned to the engine by experiment. An amplified mic and then your ear in last place. Heat is a major factor and Porsche was very conservative on the cat equipped SC, but 10 degrees of extra timing would be pushing it pretty far in my experience. It does not make sense to me that you could run that much extra timing on an overheating engine.
Bill Verburg 12-10-2009 02:32 PM
If you are going to deviate from factory specs, especially the high rpm spec i'd want it done on a dyno, and monitor exhaust gas temps/ gas content while the testing was being done.
Deschodt 12-10-2009 03:30 PM
Okay - test #1...
Drove home tonight with retard line disconnected and plugged, reset idle back down to 900....
Unfortunately my commute was rather colder and more crowded tonight than this morning... Still, I saw lower temps overall (yes this is not scientific, but I know my car very well after 14 years and it was a touch cooler than usual: 90-95C max)
Got home, timed it with all vacuum hoses off and plugged...
900= 5BTDC
2000= 10
3000= 15
4000= 20
5000= 20
6000= 20, maybe 22, everything moves more at high RPM...
Seemed low, but advance vacuum was off...
I reconnected the advance line only, and I forget the numbers now, dammit... They were a little higher overall...by 5 I think...
In doubt, I bumped the timing a little to 8 at idle... Reconnected all lines, and got about 25 degrees at 5000-6000 RPM. So far so good....
Gonna have to reenlist my helper tomorrow and recheck with advance line on, 6000 RPM in the evening scares the neighbors !
Bill Verburg 12-10-2009 05:01 PM
Keep in mind that at wot there is zero manifold vacuum. The purpose of vacuum advance wrt distributor spark timing is to ignite the lean part throttle mixtures used for fuel economy.
Deschodt 12-11-2009 01:48 PM
Even with me advancing it a little, I won't see more than 25 degrees... I doubt that is detonation region... I also wonder where the 30+ proponents are hiding ;-) Anybody ?
I probably should leave it bone stock but I saw such lower temps with more advance, it's not funny !
Bill Verburg 12-11-2009 01:54 PM
The total advance that you want will depend on cr, combustion chamber design, rpm, temp, sparkplug heat, load , mixture etc.
spec for SCs is 25* above 4k rpm
you can experiment beyond that but pre-ignition is very hard to hear
Deschodt 12-11-2009 02:47 PM
One thing that's been bugging me is how the vacuum lines affect the results, and the only adjustment numbers you find are w/ vacuum lines disconnected and plugged ! So if you get not enough (or somehow too much) vacuum, you could be off specs and never know it.
I've done the factory thing....
- I've disconnected the lines and plugged them
- Reset my idle to 900-950
- Set idle at 5 BTDC +/- 1, call it 6 on my car
- Observed that at whatever RPM, advance NEVER goes above 20 degrees. Manual says 21 +/-3 so we're covered... maybe a little lazy, but within the range !
Now what nobody seems to do: I've reconnected the advance vacuum only (left the retard line plugged) and remeasured: I got almost 30 degrees at 6000. So vacuum advance = +10, on my car! Is that the mythical 30 that is recommended by others ? Is that expected ?
Now in theory I should reconnect the retard line and re-raise my idle. But I'm sticking with Paul's idea here for a while and leaving it off.... I tested the retard vac line effect and it seems to only retard at low RPM, no effect at higher revs. Like it should, I think !
Bill Verburg 12-11-2009 03:02 PM
vacuum has 2 effects, idle retard is used solely to reduce emissions and can be eliminated though it shouldn't make any difference to full power levels due to the fact that at wot there is zero manifold vacuum.
part throttle vacuum advance is used to enhance fuel economy, it does do harm, is mostly a positve thing and should be retained whereever possible on a street engine.
here's a graph that shows the effects of spark advance on combustion chamber pressures
http://forums.pelicanparts.com/uploa...1260572341.jpg
curve 1 is what you want, as you advance full throttle timing you approach curve 2 which is where preignition is occurring, yes you are getting more power but at the expense of engine longevity
mca 12-11-2009 03:59 PM
I was under the impression that the advance vacuum would have a negligible affect at 6k rpms.
Bill Verburg 12-11-2009 04:09 PM
neither advance nor retard obtained from manifold vacuum exists at wot.
at wot the manifold pressure drops to atmospheric pressure less intake restriction + any scavenge effect from cams, which is non existent w/ any of the 80s & 90s smog cams
fumanchu 12-11-2009 04:21 PM
Why is Deschodt's timing changing from 20 or so to 30 degrees when vacuum advance is hooked up. Vacuum advance is'nt suppoded to be in the picture at WOT. From what he is saying, it is. Maybe I need to re read.
Is there a load difference when parked in the garage vs. on the road @ 6000 rpm affecting the way the vacuum advance is working?
FWIW, I run timing at 25 full advance(in by 4000 rpm) retard disconnected also. Probably a bit rich also to give some saftey as I dont know how good my CIS is at 6000 rpm.
911st 12-11-2009 04:26 PM
Not an expert. As Bill says, vac retard is an emissions thing to create heat and vac advance is a good thing to increase efficiency at mild load.
A low compression 911 can take -40 or more advance w very low load on cruse. However, it must be backed off quickly w load. It is difficult to get w a weights & springs dist. A vac advance pot can get one closer but I understand most 911's did not have them. They also should be attached to a ported vacuum that shows vac above idle.
I would look to the 2.2 & 2.4's for a hit as to how much advance that can be taking. I think some were timed in the low 30's but that may or may not have been w the Vac Advance hooked up.
Exhaust temps are good to look at. If timing is not advanced to a more ideal level, it creates more heat in the exhaust. Porsche seems to have done this, like may makers, to improve emission and during start up to help fire the cat.
However, the best way is to check things on a dyno and probably at TQ peak as that is where things are most sensitive.
Further, it should be noted that environmental conditions effect how much timing one can take. Also, ones AFR becomes a variable. If a motor is lean will not take as much timing, rich more. Thus set you AFRs first and allow room for changes in environmental factors as early cars do not have any provision to pull things back.
Here is some ignition maps I stole from 911chips.com for a stock 3.2 that might be a reference to.
Note -40 deg at light load.
http://forums.pelicanparts.com/uploa...1260577007.gif
This is a WOT map. Note no more than about -25. This mightt be conservative but a 3.2 has some compensating features built in where it can pull timing back w heat.
http://forums.pelicanparts.com/uploa...1260577120.gif
Not sure if this helps.
Bill Verburg 12-11-2009 04:32 PM
It takes time for things to come to equilibrium, so when shop tuning the vacuum is disconnected and plugged so that you don't have to hold the throttle wot w/ out a load. zinging it to 6k in the shop is not an experience which is desireable to extended.
911st 12-11-2009 04:57 PM
That is is way cool diagram. I have never seen such a thing.
Is Zb pre-ignition or detonation? I am thinking Zb is detonation.
It looks like the combination of early ignition that builds heat and pressure is kind of multiplied by an increase in pressure from the piston being closer to TDC until where the mix auto ignites or flash's instead of burning in an orderly manner.
I would suspect pre-ignition would show a spike in pressure before TDC but not sure.
I think I read that we want peak pressure at about 14 deg after TDC for peak HP. That would be Za it looks like.
With Zc the mix is still burning and adding pressure after the other two times but the piston retraction is such that the the piston dose not see as much peak pressure. This is also the condition where more exhaust heat is created as the gasses are still expanding when the exhaust cycle is started.
Can near ideal timing be measured from EGT's. That is is it the low point between detonation and late ignition? Or maybe we can start w late timing and start advancing until temps start to taper as they get cooler?
I still have a lot to learn.
Deschodt 12-11-2009 05:06 PM
I would not put too much stock in my readings with the vacuum connected. As it was explained to me by Paul, it fluctuates a lot and that is why you should measure with the lines off - I was just curious, and like Bill said, sustained 6000 RPM with no load is a bad thing...
While yesterday I did my measurements with a helper, stabilized rpm for a few seconds at each 1000 RPMs, today I was on my own so I simply zinged the motor by hand from the engine compartment, with my timing light preset at 20-25-30 to see what I could get to, maximum... So while I did see 30, it was not a stabilized thing, I just wanted to see if it could get "out there", I don't think it can...
I'm gonna keep it as is, essentially factory settings but retard line removed and plugged. And of course 93 octane only. Amusingly after all this, on my way to get pizza, I started hearing an ugly rattle from back there... I immediately thought the worst, screwed up my car experimenting with timing, or maybe one chain tensioner had collapsed - that loud... Turned out my FG bumper was rattling against one of its mounts, just a loose screw. Phew !!! ;-)
fumanchu 12-11-2009 05:16 PM
Thanks for clarifying the way you did your timing as your results were somewhat confusing. Best of luck on your setup, seems to work O.k., just wondering how much we are leaving on the table as far as power. Safety seems best in this case esp. in Cali where we only have 91 octane.
psalt 12-11-2009 06:47 PM
Greg,
You need to separate what happens at rest blipping the throttle from what actually happens under load. Vacuum advance is additive, but in practice the engine rarely runs at high rpm with high manifold vacuum. If your 35 BTDC readings were with vacuum connected, they are meaningless. Pinging happens under load when there is little or no vacuum advance. You should be able to run at least 25 BTDC without pinging under load with 93 CLC octane unless there is something else wrong with the engine.
psalt 12-11-2009 07:23 PM
This is the standard Bosch diagram of detonation, it appears in many of their books, the little Blue Handbook and Gasoline Engine Management. Z b (2) is detonation (knock), the normal 2ms burn rate is accelerated by the spontaneous explosion of unburnt fuel, causing the abnormal pressure spike. It is a bit of a cartoon and the actually pressures are different. The point to understand is that knock is not normal burning, it is an uncontrolled explosion with no benefits. The increase in pressure does not result in higher output, too much work is lost BTDC. This is why power drops once the knock limit is reached. The lower output of retarded timing occurs because of the mechanical advantage difference and a loss of heat. EGT rises as ignition is advanced, falls once knock occurs, but is not a safe reliable indicator for tuning. Peak CO2 can be a good indicator of ideal ignition timing. With all hemi headed engines with wide VIA's and domed pistons (like a 911) it is safe to assume they are knock limited on pump fuel. The "ideal" timing can only be found using the highest octane race fuel, then they are retarded (detuned) for what ever octane fuel will be used, plus a safety margin. The peak output for N/A hemi head road race engines was in the 50's when they ran 14:1 compression, domed pistons and 50 BTDC ignition timing. The reason this was possible was they were burning butyl alcohol, methanol, benzene and nitro instead of gasoline and the fuel acted as a coolant to prevent detonation. Corn politics aside, E85 could be a 911's best friend.
psalt 12-11-2009 07:40 PM
Yes, load means the engine is pulling against something, not sitting in neutral. Is there a difference between the way the engine's rpm rise when blipping the throttle in the garage in neutral and when you floor the throttle going up a steep hill in 3rd gear? In the garage when you are blipping the throttle, you cannot hold it open for more than a second or you will overrev the engine, and there is plenty of vacuum around to screw up the timing reading. The vacuum advance is there to add timing when you are cruising at 60 mph and there is 16 inches of vacuum in the manifold. At 130 mph @ 6000 rpm with the throttle open there is less vacuum in the manifold than the threshold of the advance and no extra timing is added. As soon as you floor the throttle on the road, the extra advance disappears immediately.
When tuning an engine, you have to separate what happens when it is working and what is happening at rest. The same situation occurs with measuring AFR's. Measuring AFR's at 3000rpm in neutral in the garage is also meaningless. It is what happens under load that matters.
911st 12-12-2009 09:00 AM
On a 911 w Vac advance timing in the driveway at 6k will be advanced if the vac advance is not disconnected. Under WOT the vac would go away and timing would be less.
However, it seems most SC's have "Vac Retard". This should be hooked to a vac line that only lets it work at idle. Thus, even if it is left hooked up it should not effect in the driveway timing.
psalt,
Thx for the info. I would like to see a graph for pre-ignition. I suspect that in most cases it would show the pressure spike earyer than detonation.
You note that EGT increases when timing is advanced. That makes sense as it is making more power.
I think there is also a point where it increases when timing is retarded as the fuel is still burning in the exhaust (i.e. vac-retard). I thought old race cars used EGT's to tune but that must be on the fuel side?
Still, setting timing on a Dyno after the AFR's are confirmed w someone that knows what they are doing seems the best way to go remembering to pull things back to provide a margin of safety as an SC can not manipulate timing to deal with changing environmental conditions like an EFI car can.
Better yet, a mapped programmable MSD could make for a significant improvement as the timing curve can be bent to better fit the motor.
Fun stuff.
psalt 12-12-2009 09:27 AM
The engine in question, an 83SC, has both vacuum advance and vacuum retard. There is no "should" or "thus" about it, both need to be disconnected and plugged to accurately measure the timing against the factory spec. The retard is hooked up to manifold vacuum. Try it yourself and you will see your error.
Pre ignition is almost never an issue on a N/A road car engine and is usually a red herring in these discussions. Everyone I know that can speak intelligently on this topic uses the term "knock". The Bosch chart shows the ignition point before the pressure spike, so it is obviously not pre ignition. The best way to understand this issue is to start with the indicated pressure diagram of an SI engine and get an understanding of peak cylinder pressures. An engine with a cranking compression of 180 psi, will show a peak cylinder pressure of +600 psi running, and this can jump to +2000 psi under detonation. The magnitude of the pressure spike is one issue, when it occurs and how fast it rises is another.
Bill Verburg 12-12-2009 10:41 AM
In post #14 I usually used the term pre ignition, my apologizes.
preignion is the early initiation of aa flame front in the combustion chamber, usually from a hot spot, but it can alos happen because of too much pressure too early.
The Bosch diagram shown in the same post is illustrating abnormal combustion due to high cylinder pressure though not occuring as early as preignition. The effects are similar, damage to rings pistons, valves etc can and will occur. Sometimes you can hear the engine knocking but most of the not.
It's your engine and if you want to experimant have fun, but beware of the potential for damage.
Demetri 12-12-2009 04:17 PM
Now that you guys have your heads wrapped around this, perhaps you can help me out. Where should I set my timing?
I have a 83 SC ROW with only one vacuum line on the distributor. I sometimes hear it knock, usually on hot days . It's set at 5 BTDC and gets up to about 35 at 6000 rpm. As stated before, here in CA we only have 91. I put in 100 on occassion, and that seems to do the trick. But at 6 bucks a gallon, I can't do it all the time. Any advice wouid be appreciated. thank you.
911st 12-12-2009 04:31 PM
This is just a guess based on an optimized EFI ignition table I have for a low compression 911. Something in the -28 to -30 static w no vac line at hight rpm should be ok.
It might take more depending on fuel quality, AFR, and temp.
I am not very sure about this. I always thought timing for a 72 911S at 5k was in the -32 range. That is with a cam that lowers effective compression a bunch.
On my 2.8 RS MFI twin-plug running over 10/1 CR is was about -24.
Can anyone verify the 72 911T, E & S timing spec?
Demetri 12-12-2009 09:50 PM
911st,
That makes sense. I think. I do have a higher compression motor. What was the timing of on your twin-plug at 900 rpm?
I have set mine at 2 TDC and richened it up a bit. That took care of the knock, but did not make for a smooth ride. It always felt like i had to be on it. Good for me but bad for the Mrs., which means bad for me. You ever see that Mr. and Mrs. Potato Head commercial?
Would retardeding my timing from 5 to 2 BTDC at 900 rpm, make it go from 35 to 32 at 6000 rpm?
Mothy 12-13-2009 02:42 AM
What would be the main reason for doing all this? HP, Torque, Emissions, Economy?
It's an interesting read to follow as to the methods or approach, pros and cons etc. but for someone like me with limited knowledge of finer technical aspects, I'd like to know why you would vary from the factory settings in the first place. It also makes the thread more complete as a reference.
Tim
DanielDudley 12-13-2009 04:41 AM
Mothy, the way I understand it, gasolene takes time to burn. From the moment you spark it, a flame front starts and spreads through the combustion chamber. You want as much of that flame burning as possible when the piston is close to top dead center, so that the piston will have push during the whole downstroke.
Of course as the engine revvs higher, you have less and less time for the spark to ignite. If you are at 0 degrees advance at 6000 RPM, your flame might not be burning well intil you are well into the power stroke, so you are losing power. Advancing the spark will put a smalll flame into the chamber before top dead canter, so that there is a decent fire going during the power stroke.
Of course, at 6000 RPM, things are happaning six times faster than at 1000 RPM. You do not want very much advance at low RPMs or the flame will travel too fast, and actually push down on the piston as it travels up to top dead center. This will often lead to an engine that balks when cranking it over to start. But the real issue with too much advance is that you have maximum compression at top dead center in the power stroke. The explosion of the spark creates a further increase in compression, and this can cause the gas air mix in the combustion chamber to spontaniously ignite far away from the flame front. This is called, knock, dieseling, pinging or preignition.
The combination of the two flame fronts creates way too much pressure way too early, and leads to extremly high compression, and a shock wave where the two flames meet. It also leads to very high temperatures, and the pressure isn't really usefull at pushing the piston when before top dead center or at TDC, so the heat and pressure attack the piston and rings, instead of moving them.
In a 911 motor, it is also worth noting that the Valves are very large. In this case, the spark plug has to be on one side of the chamber or another, as the valves are close to touching in the center. This means that the flame front has to travel much further to reach the opposite side of the chamber. This gives the gas air mix more time to spike compression during detonation, and makes the 911 engine more sensitive to too much advance than a four valve engine, where the plug is smack dab in the center of the dome. It also requires that the pistons have a dome to increase compression, and this can lead to other problems.
In fact, when you hear about twin plug heads, the idea is to have two controlled flame fronts on either side of the valves, so that the controlled burns only have to travel 1/2 as far, and thus pre ignition is prevented, and a much softer explosion takes place at the correctly timed interval. This is why you need to run twin plugs with high compression 911 motors.
Finally, we need to realize that the reason that predetonation pinging only happens during full throttle application is due to the fact that more fuel and air are being sucked into the chambers at WOT. Too much compression + too much fuel + too much advance = knocking. The reason higher octane fuels can prevent this is because octane relates to resistance to ignition. That equates to resistance to preignition in a high compression motor.
I hope that was somewhat clear.
don gilbert 12-13-2009 05:56 AM
being a semi pro drag racer for 20+years, we advance in small increments until pinging is heard, and then back off a degree or two. which i know is hard to hear on a 911 if you are not used to what detonation sounds like. I like to load my pcar in 3rd, up a hill, and i can tell if its pinging. I run 33 degrees max, (retard line disconected, have 9.5 comp. use 93 octane shell, and have an afr gauge to check the mix at all rpm. Too lean a mix and to much advance is not good. A dyno makes things easy, but not all have acc. to one.
psalt 12-13-2009 06:21 AM
Demetri
Your engine has higher (9.8:1) compression and was tuned to run on 98 RON with 25 BTDC max ignition timing. 98 RON is around 93 CLC octane fuel. Unless you are a magician, you can't run the engine on lower spec fuel with 10 degrees more advance, than the factory could. The answer is you need to raise the octane of the fuel or reduce the timing. Your distributor should only give 20 degrees of mechanical advance, so I would first check it is the right part number, then question your measurements. You also want to check the AFR at WOT to make sure it is not too lean. The only ways to lower the octane requirement of your engine is to improve cooling, lower the intake air temp, or get the oil mist out of your intake.
psalt 12-13-2009 07:14 AM
Daniel, you are almost there, here are a few thing to consider:
>You want the fuel to burn so the peak cylinder pressure occurs around 14 BTDC, not TDC, to maximize output. All of this discussion is at WOT under load, when max output, torque and VE occur. Different things are happening the 90% of your driving at part throttle. Think of it this way, if you had an in cylinder pressure sensor, you would adjust the timing advance to peak at 14 BTDC at every rpm.
> the burn time is around 2ms. There is something called ignition delay, so you need some advance even at lower rpm to get the pressure peak at 14 BTDC.
> If you study the indicated pressure diagram of a SI engine, you will see that all engines are fighting the compression pressure. The work lost on the compression stroke is offset by the work done on the expansion stroke. Since all engines use ignition advance and the more the advance, the more work lost on the compression stroke, the concept of MBT (minimun advance for best torque) is used.
> These terms have different meanings , it is a mistake to interchange them. The spark does not create an explosion. The best way to understand this is under normal combustion the fuel is burnt in a regular four stage process. Under abnormal combustion, the fuel explodes. You do not want the fuel to explode.
>The history of the hemi goes like this, the initial race engines of the 1920's had small bores. In order to get decent sized valves in a small circle, you need to splay them out and use a wide VIA, first over 100 degrees, then 90. The wide angle results in a higher bigger volume CC, so you need to use domed pistons to get a decent compression ratio. Now, think of the dome piston at TDC and you have an orange peel combustion chamber. Later designs narrowed the VIA, Jaguar used 70 in the 1940's, Porsche 59, BMW and Lotus 54 because of this problem. There was one American that used 38 in 1919. The 1912 Peugeot, four valve pent roof chamber does not have this problem, but it was masked for many years because of fuel chemistry.
> this drops the MBT around 10 degrees. For example, the ignition timing on a twin plug 917 was a fixed advance of 27 BTDC at all rpm.
> predetonation pinging is an oxymoron, you can't have a noise from a shockwave before it happens unless you are clairvoyant. I find it much clearer to think of normal and abnormal combustion, burning or exploding (knock). Too much fuel is not an issue, more likely not enough. Nothing below 14.1:1 burns anyway, the extra fuel for max output, 12-13:1, is a coolant to allow more timing. Preignition occurs before the spark event, so unlikely in a N/A road car in operation, to be just added confusion.
Learning about how a diesel engine work, the pressures involve and why knock is not an issue helps a lot in understanding this problem.
psalt 12-13-2009 07:36 AM
38 BTDC, vacuum disconected, max advance. Sunoco 260 was 39 cents a gallon.
psalt 12-13-2009 07:50 AM
Hello Tim,
The hot rodders and posh wannabes are always looking to "improve" things with their skills. The post unleaded fuel US 911's are detuned and advancing the timing increases power, if you have enough octane. For some models and locations, US fuels have improved since the mfg date and a small amount of extra advance helps a small amount. Porsche got it right from the beginning , but once you significantly modify the engine, remove the cat, change the intake and cam, etc. the factory spec is only a starting point.
911st 12-13-2009 08:31 AM
38 BTDC, vacuum disconnected, max advance. Sunoco 260 was 39 cents a gallon.
Wow, that is a lot of timing. They were only 7.5 and 8/1 CR motors if I remember correctly. They also had higher over lap valves that lowered the effective compression. They also had a shorter flame path. I guess that all added up to a very slow burn.
I could see -38 with vac advance and more like -32 disconnected. Might be worth verifying as Porsche did have a test w the VacAdv hooked up as well as not. I am probably wrong on this.
A change in timing up top of two deg effects timing at idle the same amount. That is because the mechanical advance is a fixed amount. Vac advance and or retard is accumulated with this.
More ideal advance at cruse is going to improve fuel economy.
More ideal advance under load is going to improve power.
Less than ideal advance at idle allows for easier starting and improves emission at the cost of response and economy. It also create heat.
Risk of detonation is usually highest at TQ peak. Thus, with a weights and springs mechanical advance modified by a vac or retard pot is going to be at less that ideal advance much of the time even if set at the limit at the most sensitive point.
Risk of detonation changes w AFR, air density, temp. If we set it at its ideal under one set of conditions, it will be at less than ideal at other times.
Thus, a programmable electronic ignition w the right sensors can be more accurately set to run at the ideals more of the time.
MSD makes a programmable unit. This could be something to look at. With its multiple sparks at low rpm it might also help throttle response as CIS seems to have a lean surge with first acceleration and a lean mix is harder to fire.
I am more of a 930 guy. With the 930's timing was set to about -26 at hight rpm or about -16 on boost. When Porsche added electronic ignition to the 91 turbo they seem to have set it up for up to -40 at cruse and closer to -20 on boost. They could do this because there was compensation for temps bullt in and a programable sustem could do things the mechinical system could not.
Thus, there is margin built into the stock system for reasion of safety, emmissions, and fuel quality vartions. If one is carfull these margins can be tested for an increase in both economy and power.
psalt 12-13-2009 09:38 AM
Most "absolute" statements about what more or less timing does are incorrect because of the number of variables involved. Some engines need very little advance for MBT and knock is not much of an issue.
Speculating about why the timing spec is the same for 3 models with 7.5, 8 and 8.5 compression engines is a good example. More info is needed. AFAIK, the prior versions all had different octane fuel spec's and these models were all spec'd for 91 RON unleaded, a drop of 7 octane numbers from the 9.8 S. The factory did point out that performance numbers all improved, but after the political events of the embargo, consumption was the number that mattered. So they took a different path, raised compression to improve consumption, and detuned the timing to prevent damage. Advertising for the later SC and Carrera focused on performance increases with consumption decreases. The distributor spec is 32-38 max, which shows the slop in a mechanical distributor even when new.
Normally a larger bore would require more advance, but after 1972, it was a politics not performance that dictated timing specs.
