Cam timing used the 16 hole / 17 hole and pin arrangement shown on the right hand cylinder bank
Bucket followers acting directly on valves shown on the left bank, with lash adjustment via small caps on the end of each valve stem. http://forums.pelicanparts.com/uploa...1260738243.jpg (C) IME 1972 |
So valve adjustment was via different size 'caps' similar to the shims used in Ducati valve adjustment? |
| All times are GMT -8. The time now is 06:37 PM. |
