juicersr's Avatar
917 engine animation
Thought this was pretty cool to stare at for a while, especially at full screen... if it's a repost, sorry.
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 12-10-2009, 01:48 PM
pretty cool
Old 12-10-2009, 02:11 PM
Bill Verburg's Avatar
very nice!
Bill Verburg
Old 12-10-2009, 02:29 PM
Awesome video, but what supports that big gear?
Also, what did they call the shaft drive that turned the distributor etc.?
1972 911T/S MFI Survivor
Old 12-10-2009, 05:55 PM
Alii&Maui
Jesset100's Avatar
That's a keeper!
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 12-10-2009, 07:35 PM
CorsePerVita's Avatar
That's cool!
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS
Old 12-10-2009, 07:39 PM
T77911S's Avatar
i think the cams need to be checked, the timing looks to be off about 5 degrees.
pretty cool. that would make a great screen saver. anyone know how to do that? i would never touch my computer.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-11-2009, 04:57 AM
juicersr's Avatar
The shaft which drove the distributors and flat fan was known as the 'skew shaft' i believe. As for the support of the large intermediate gears which drove the camshaft, assume it was a similar bearing set-up as the intermediate shaft in the 911 engine. If more knowledgeable minds care to chip in, would be great.
The cool thing about this CAD animation, is that the guy that did it states he used simple pix from books, some photos and a couple of diagrams, similar to the guy that built the minature working Ferrari 512. I am always amazed at this integration of technical and artistic expertise.
dzugautomobili.com
Old 12-11-2009, 06:36 AM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
the big gear you see is the intermediate cam drive gear - both upper (intake) and lower (exhaust) cams are driven off that gear.
what's not so obvious in the video is that power is taken from the crankshaft at the middle - not the end. Like the 911, the 917 (type 912) engine has an intermediate shaft, however the 917's intermediate shaft takes power from the crankshaft from a bevel gear in the center, and then turns the flywheel at the back of the case.
really neat, thanks for posting.
Mark Petry
Bainbridge Island, WA
81 SC
Old 12-11-2009, 08:21 AM
Sorry for the mundane questions but...
It's clear the large gear is driven by a gear on the crank. What is not clear to me is where the shaft would run that supports that large gear. It looks like it would interfere with the piston rods.
Old 12-11-2009, 10:37 AM
Nice !
Juicersr > it is a 312PB, i met him, i have pics of the (amazing) model
He met the guys who built the car in italy too ...
Old 12-11-2009, 12:59 PM
Quantum Mechanic
mpetry's Avatar
The shaft supporting that gear does not run the full length of the engine. it's on a "tower" that goes between the case and the rocker boxes, between the two center cylinders. I'll see if I can find a pic for you. there's also some great pictures in "Excellence was expected" volume 2 that clarify things.
Here we go. See that gray "dot" of sealant? Thats the end of the stub shaft supporting that big gear, which turns the two cam drive pinons.
Pretty neat, huh ?
Mark Petry
81 SC
Old 12-11-2009, 01:37 PM
BURN-BROS's Avatar
Here is the 4.5 liter 917 crank with drop shaft. The gear on the left end of the drop shaft runs the oil pump. The splines on the right are for the flywheel.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 12-11-2009, 02:38 PM
Quantum Mechanic
mpetry's Avatar
The lower shaft is titanium and I believe that the crank was forged in 2 pieces and electron beam welded together with the gear in the center.
Those parts used to be worth their weight in gold. I'd have to check if that is still true at $1200/oz.
Mark Petry
81 SC
Old 12-11-2009, 02:44 PM
That is so awesome!
Old 12-11-2009, 03:02 PM
juicersr's Avatar
Does anyone here know how cam timing was set? Also, were solid tappets vs rocker arms used?
dzugautomobili.com
Old 12-11-2009, 06:21 PM
Burn the fire.
Brando's Avatar
I saw some pictures in a thread earlier... Looks like they used tappets.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 12-11-2009, 08:12 PM
Originally Posted by philippeF View Post
Nice !
correct...the model is of 312 pb.
Old 12-11-2009, 08:18 PM
Quantum Mechanic
mpetry's Avatar
Ferrari Pete is correct, there were no rocker arms per se, instead, tappets that bear directly on the cams. The twin cam engines in the 962 and 959 have a similar valve gear arrangement.
Mark Petry
81 SC
Old 12-12-2009, 04:23 PM
Eye of the Toiger
matty74's Avatar
awesome, my fav porsche motor
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 12-12-2009, 11:23 PM
