1974 911 w/ 83 SC engine
Porsche 944 Turbo brakes on a 911?
Apparently I have the brake calipers from a 944T in my 1974 911. Is this a popular "upgrade" or did my PO not want to pony up for real 911 parts for one reason or another? The front rotors are from a Carrera, with the 944 calipers. The brakes work, but damn you gotta leave a lot of stopping distance between you and whatever you don't want to hit. If 944 brakes on a 911 are an upgrade, what's the_upgrade_over that? Cause these aren't cutting it...
Old 10-15-2009, 06:11 PM
Bill Verburg's Avatar
Sound like bastardized setup to me. Another backyard engineer strikes again
you apparently have at least 2 separate but related issues
issue 1- inappropriate calipers
issue 2-inappropraite m/c
some extra infromation is needed, I assume that 3.5" struts are being used
are the 944 calipers used in back also?
I assume that your complaint is related to extremely high pedal pressure?
Bill Verburg
Old 10-16-2009, 04:16 AM
djpateman's Avatar
In addition to what Bill says, try and check the piston sizes in the 944 calipers. The 944 turbo front and rear calipers are very similar, but piston sizes are way different; 38 & 36 front vs 30 & 28 rear. If rear calipers were used on the front of your car there would be very poor braking performance. It is not uncommon to be fooled by the size of the caliper.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 10-16-2009, 05:40 AM
Non Compos Mentis
I wish my 911 had the brakes of my old 944 Turbo.
I've been using an old 15" Cookie Cutter for my spare. I just acquired a 7x16 Fuchs so that when I upgrade the brakes, I have a spare that will fit.
Old 10-16-2009, 08:00 AM
The 944 system which consists of calipers, rotors and m/c is a fine setup when used in it's entirety(w/ a minor m/c substitution due to the physiacl difference between 944 & 911)), taking a piec here and a piece there and slapping it somewhere else is not a good way to set up a car.
Bill Verburg
Old 10-16-2009, 10:33 AM
Steve Weiner does it right with 944 Turbo brakes on 911s. Contact him at porsche@rennsportsystems.com if you still have questions.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-16-2009, 11:15 AM
Non Compos Mentis
Precisely why I haven't touched the brakes yet!
I don't believe in swapping a part or two at a time. When I decide the best brake SYSTEM for my car, I will do it all at once, and be done with it.
Steve Weiner is just down I-5 from me. I'll probably be talking to him when I'm ready.
Old 10-16-2009, 12:55 PM
Those are actually 930 ones,.......
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
www.rennsportsystems.com
Old 10-16-2009, 02:50 PM
Who'd a thunk it. All along I thought mine were 944s. Now my SC is worth $85,000, not just $80,000, I guess...
Stephan Wilkinson
Old 10-16-2009, 03:20 PM
Its not simply gold-plated, anymore,........
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-16-2009, 04:22 PM
Here's what I've found: I have a 1974 911 (non-power brakes), but with Carrera front struts and rotors, and red 944 Turbo 4 piston calipers on the front. Is this the normal way the "upgrade" is done? The back brakes weren't touched. I'm just annoyed cause to do front brake work I have 3(!) different cars I have to reference: 74 911, god-knows-what-year Carrera, and god-know-what-year 944.
Old 10-16-2009, 05:28 PM
That's a kludge
here's what you want to do
retain the struts, front rotors(I'm assuming that they are the usual 24mm 3.2 Carrera rotors used on these sort of things) and rears as is, just be sure that they are nominal. Get some nice soft street pads
Get a set of '84 -89 911 front calipers, bolt them on
Check the m/c to be sure that it is a 19.05mm, not a 23.8mm. The m/c bore is embossed on the side of the casting, usually you can read it w/ a flash light from below.
If you can' read it the 23.8 is longer and will come right up to the cross member, if it's a steel cross member it's almost impossible to fit a 23.8
here's what a 23.8 looks like installed
and here's a side by side, 23.8 on top
Bill Verburg
Old 10-16-2009, 05:43 PM
axvel's Avatar
Send a message via ICQ to axvel
i have all 4 944t calipers and they are great!!! on a 1977
Old 10-17-2009, 07:47 PM
What pads and brake fluid are you using? Are you using the original size rotors? Did you specifically want those brakes or were they on the car when you bought it? Are the 944T brake calipers the same for every year the 944 was made? See, my problem is if I want to get new pads I don't know what year/or option package these brakes are. I know that's a lot of questions, but if you are running the same setup, I'd love to know more...
Old 10-17-2009, 10:07 PM
axvel's Avatar
I'm using blue fluid from pelican, i have the brakes from the 88 944t, when i recently changed the pads, i requested the 944t 1988 year, very simple.
I got them because i wanted larger less expensive caliper look, similar to the 964.
The rotors i used very orginal ones for 1977 911
if you have anymore questions let me know
Old 10-17-2009, 11:31 PM
On my 1980SC I have 944T fronts with 28 mm rotors and use 3.2 Carrera 24mm rears and their matching calipers without a proportioning valve. Decent balance (slightly front biased) .I have a 23 mm master but haven,t gotten around to installing it yet. Street driven with 3.6. Seldom think I need this much brake,but like the looks anyway.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 10-18-2009, 06:25 AM
I know that you don't want to hear this but that is another kludge
964/944 fronts want a 28mm rotor, the usual 24mm rotor used is bad enough but a stock 20mm is downright dangerous.
Bill Verburg
Old 10-18-2009, 06:54 AM
This one is a decent setup
Bill Verburg
Old 10-18-2009, 06:55 AM
I agree that 20 mm fronts are DANGEROUS. Part worn pads could allow pistons to fall out of calipers.
The other problem the original poster must be experiencing is HUGE front bias with the original small piston rears.. No wonder his stopping distances seem poor.
Return to stock or cheap upgrade to 3.2 Carrera fronts (calipers AND rotors) would be my opinion.Then add red plastic caliper covers for the 4 piston bling look
1995 993 coupe
2012 Boss 302
Old 10-18-2009, 07:44 AM
axvel's Avatar
Bill, i'm very interested in your opinion, could you further explain please?
I currently have the zimmerman rotors for 1976-85 that i ordered from our host, also the pads are new and they brake like crazy. Instant stop. What could possibly go wrong?
If you have a recommendation for the good rotors to use please let me know. Our host doesn't list the width of the rotor.
Old 10-19-2009, 01:24 PM
