Jupiter 911
bklyn's Avatar
Fuel filter replace question.
I have my 101 book but I need to ask, when I replace the fuel filter, should I put some teflon tape on the treads?
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 12-12-2009, 03:48 AM
Almost Banned Once
sc_rufctr's Avatar
No need for Teflon tape or anything else.
Just clean the threads and tighten it firmly but don't over tighten it.
>>> Good and tight but not to the point of deforming anything.
Don't let you fuel lines twist.
The seal is created by the bulb end of the fuel line sealing against the fuel filter.
- Peter
Old 12-12-2009, 04:42 AM
Somatic Negative Optimist
Gunter's Avatar
As mentioned, don't stress the lines.
To avoid twisting the lines, use 2 wrenches: One to hold the filter by the hex on it, and the other wrench opens/closes the cap nut on the lines. If you position the 2 wrenches the right way, you can squeeze on both of them in a scissor-action to open and tighten.
Put a big rag under the filter because some fuel will leak out and a fire extinguisher nearby doesn't hurt.
Depending on what type filter you have, the nipple on the old one may have to be re-used.
Mark the date and Mileage on the new filter so you'll know in the future.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-12-2009, 08:29 AM
Jupiter 911
bklyn's Avatar
As always, thanks gents.
Old 12-12-2009, 10:34 AM
