SAIGON 68
johnnywishbone's Avatar
HOW TO MAKE bumperettes GO AWAY?
can i obtain trim pieces to make 1978 930 bumperettes GO AWAY?
seems like it would clean up the back end.... thx, jp
Old 11-20-2009, 11:42 PM
Now in 993 land ...
aigel's Avatar
General solution is to unbolt, fill holes and repaint bumpers. And some people shrink them by installing the Euro pieces. Personally I think they look ok - period correct, so to speak.
George
81 SC (sold)
Old 11-21-2009, 12:37 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
I removed the bumperettes from my rear bumper....filled the holes and repainted....it is being replaced with an IROC bumper this weekend to go along with the 930 flares....if you want a bumper to replace yours without all the work and with good rub strips let me know.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 11-21-2009, 02:55 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Here we go...
Extreme Makeover, Carrera bumper
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 11-21-2009, 04:06 AM
I took a very easy route: Removed the bumperettes and drilled out the small holes in the bumper to be the same size as the larger holes. Then I went to Lowes and bought plastic plugs to snap into the bumper holes, and painted them body color. When I autocross at an event that requires stock bumpers I remount the bumperettes in five minutes with wing nuts. The hard part (or fun part, depending on your definition of recreation) is recreating the license plate lights that you lose on the bumperettes. There are many solutions, using various configurations of mounted LEDs available on the internet.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 11-21-2009, 05:13 AM
Virginia Rocks!
VaSteve's Avatar
Here's the part I'm always not getting....the thin strips are held on with that plug and it looks like they are pincher under the bumperette? Do you have to pull them out from under in some fashion?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 11-21-2009, 06:17 AM
There is a screw under the plug. When the bumperettes are removed the tip of each strip tends to peel away from the bumper. As I recall, I had to drill a small hole in the bumper at the tip of each thin strip. I then used a black anodized self-tapping screw to secure the strip tip. Doing so does not prevent reattachment of the bumperettes.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 11-21-2009, 06:41 AM
1986 Targa 1972 RS clone
magnuskgc's Avatar
Hey Howard can you get a closer picture of the rear bumper setup... I never considered that option.. would like to see how it looks.
Old 11-21-2009, 07:21 AM
Virginia Rocks!
VaSteve's Avatar
So if I take out the plug and then the screws, isn't the strip held down by the edge of the bumperettes? Would I need to remove the bumperettes while the bumper was still on the car?
Old 11-21-2009, 09:40 AM
rfloz's Avatar
You might also take a look in The Official Modified Bumpers Thread:
The official modified bumpers thread!!!
Bob F.
1984 Carrera Factory Turbo-Look
Old 11-21-2009, 09:49 AM
The bumperettes are removed with the bumper still on the car. I have never removed my rear bumper. The screw under the trim plug does seem redundant with the edge of the bumperette, which you would expect to hold down the end of the trim strip which terminates under the bumperette. However, I remember that the ends of the trim strips curled away from the bumper when the bumperettes were removed, requiring the small hold down screws mentioned earlier. I'll try to take a closer photo tomorrow or Monday.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 11-21-2009, 07:27 PM
I'd recommend removing the bumper. You would not believe how much junk is in there. It isn't the easiest project on an older car but worth it IMHO.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 11-21-2009, 09:47 PM
Happiest when Tinkering
gsmith660's Avatar
Here is what I did. Details are here in my build thread the bumper work starts toward the bottom of the first page.
What I have been doing for the last 2 years!
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 12-13-2009, 04:41 PM
