Out of Patience with my Auto Heat!!!!!
Can I just buy the parts and convert my Auto-Heat to a manual system? I just can't see wasting all this time on analysis if I could just bolt in a manual system that would probably work a lot better.
If so, should I be able to find the parts at Hershey, or is stuff like this hard to find?
Thanks so much.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 03-11-2013, 08:44 AM
ROW '78 911 Targa
timmy2's Avatar
Rip it all out and backdate it. You'll wonder why you waited!
Old 03-11-2013, 08:58 AM
I've never really needed to use my auto heat, just use it in manual mode.
Scott
'78 SC mit Sportomatic - Sold
Old 03-11-2013, 09:32 AM
Scott R's Avatar
It's almost as easy as you think. Remove the autoheat console and tuck the wires away. Now here is the catch, you will need two new heater cables because the auto heat system ties the two cables into one lead and it's not long enough to work with the manual levers.
I got some stainless steel wire from the hardware store and ran new lines from the flappers back. I also hooked my footwell blowers up to the switch attached to my manual levers.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-11-2013, 09:33 AM
pete3799's Avatar
I just popped the rod off the actuator and pull the handle ( one lever) manually.
If i want the blower on i just turn the dial.
Pete
79 911SC RoW
Old 03-11-2013, 09:55 AM
