911sc won't start after stalled by painter.......
hello,
I drove the car yesterdayı to the painter.
He called today, the car suddenly won't start after he drove it into the garage.....
The battery from the transmitter (Gemini alarm) was empty.
I put a new battery in the transmitter but no start.
I have no spark on the plugs.
No 12v on the coil
The fuse's are ok
The cdi box is making noise, seem the be ok.
The motor is cranking but won't start.
Anyone that can help my
Old 08-25-2009, 10:06 AM
Just in case your mistaken about no spark, check for a back fire valve in the air box. Very common problem having the valve pop open on a back fire and not closing/sealing. If the painter is not used to CIS this could of happened.
Old 08-25-2009, 11:15 AM
another vote for checking pop off valve. Mine stuck open a while back and did the same thing.
Old 08-25-2009, 11:36 AM
So, the pop off valve open, can cause no spark on the plugs.........
correct my if i am wrong.
Old 08-25-2009, 12:19 PM
No sir,
I wasnt very clear about that. An open pop valve will keep the engine from running but you should still have spark. Does the ignition box make a high pitch whine with the key on?
Old 08-25-2009, 12:24 PM
Plus one for pop of valve. If it has blown. SOmetimes it will be sitting in airbox and needs to be reglued! Won't start if it is not closing.
Old 08-25-2009, 02:15 PM
DP935 member
kycarguy 935's Avatar
Check the electrical plugs on the electric panel in the engine compartment. The color sanding can cause the water/paint to cause the contacts not to make a good connection or connection at all.
I actually had the same thing happen before and spent hours trying to find the cause. I couldn't believe it was such a simple problem.
Good luck and let us know.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 08-25-2009, 02:54 PM
Capitator 600v 1.4uF is death
Anyone knows where a can Buy One???
Old 12-15-2009, 08:27 AM
