Post Speedometer making clicking/grinding noise
Anyone know what might be causing this? Speedo bounces especially when slowing down through about 30 to 0. Clicks correspond to bounces. Is this something I might be able to fix or do I have to send it off somewhere for big bucks. Thanks
Dan S.
1974 911 Targa
Old 06-18-2001, 11:22 AM
I had this problem with others cars, not the P-car. Turned out to be the speedo cable and not the guage. Check the connections at both ends. It may have come loose.
Paul
78SC Targa
Old 06-18-2001, 11:39 AM
Post
same here too, but the speedo cable just needed to be lubricated. do this at the connection.
Old 06-18-2001, 12:22 PM
Post
Thanks guys,
Can I assume I get at it through the trunk and not through the dash?
Dan S.
1974 911 Targa
Old 06-18-2001, 12:42 PM
Post
Pull the speedo out of the dash and you will be able to grab the nut of the drive. Should work "hand tight" w/o tools.
Getting there through the trunk requires removal of the fresh air unit as far as I remember.
Jens
'76 2.7 CIS with '73 body conversion
Old 06-19-2001, 01:23 AM
Post
Thanks Jens,
I guess at this point I should point out that the only manuals I have are Clymer and Haynes Would the Bentley manual or upfixnderporsche cover procedures like this. I hate to just start tearing stuff apart due to my propensity for totally Effing up most everything I touch on this car.
Dan S.
1974 911 Targa
Old 06-19-2001, 11:02 AM
