declang's Avatar
Route of HT leads on MFI engines ?
Hi folks,
I've been searching for photos of /83 engines showing the route of the ht leads from distributor to the plugs.
So far, this is the best I've found, but still touches the throttle cross-arm at times. I have a sneaking suspicion they should be routed out of sight behind the alternator & then maybe out through the TB's ?
Thanks,
Declan
1975 911 2.7 Coupe
Old 12-16-2009, 08:31 AM
kwikt 911's Avatar
That's where mine are routed. Although I believe they should be routed between the MFI stacks in those rubber u-shaped holders.
Old 12-16-2009, 10:04 AM
