Weltmeister 2" Shift Lever Extension
I had 10 made and it works great! The 1" Section is a very tight fit into the WM Lever. I had to remove the inside lip and then used 2 hour epoxy Glue. I have the knob about 1/2 inch above the WM Lever and the Shift Throws are a little shorter than the Porsche Short Shift lever. Remember, the Step in the WM lever about 2 inches down from the Knob is how the WM is made. The Joint between the extension and the WM Lever is about 1/4 inch below the Beauty Ring on the Shift Knob.
Old 12-14-2009, 05:28 PM
Less brakes, more gas!
euro911sc's Avatar
I have drawn this out a dozen times and never pulled the trigger... The other way of doing it is by cannibalizing an old shift lever and using the plug to join the two sections. A bit of paint and you can't tell it has an extension on it...
Can I get one of these? Seems like a good product ot have Wayne add also. Did you make it out of steel? Looks like it...
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 12-14-2009, 07:39 PM
-Michael
Sure, I Figure $20 for the extension and $5 to cover the Mailer, Postage and Delivery Comfirmation. Yes they are made out of steel and the only instruction I need to make for it is to remove the inside edge of the WM Shifter lever because the Fit is Close. You cannot tell by the Pics but the Glue-in part has ridges about every 1/8 inch to help the Glue to have something to hold on to! Send me a PM with your information and I will give you mine.
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 12-15-2009, 07:54 AM
To answer a question that has come up! A stock lever is about 0.040 inch larger in ID than the WM Lever. I do not know if this holds true for the Factory SHort Shift lever. The OD of the part of the extension that is glued into the lever is 0.380 inch and the OD of the extension is 15 MM or 0.590 inch. Me feeling is that yes it can be used to extend a factory lever but more care will be needed to hold the extension straight and more glur / JB Weld to fill the 1/2 MM (0.020" Space around the Extension.
Old 12-16-2009, 09:02 AM
