loose nut behind wheel
cudabnu's Avatar
915 Trans ID
How can I ID a 915 trans that looks like it had been dragged across the floor, and the numbers are not readable? It is missing the differential and stubs. The person selling it can get me any pics needed.
Tks!
80 911sc/993 GT-2 body/3.6L motor
71 VW Convert (300 hp 2332 FI turbo)
97 Passat TDI 320K miles and counting
Old 12-18-2009, 11:39 AM
peon77's Avatar
How many teeth on the pinion gear? 7 or 8
what kind of metal is it? mag or alum
Does it have a mech speedo hook up?
75 911s
86 951 sold to make room for baby seat
09 335i 6MT
NVH
Old 12-18-2009, 12:08 PM
Peter Zimmermann's Avatar
If it's a magnesium case (housing) it'll be a '77 or older. If it has a connection on the nose for a speedo cable it'll be a '75 or older. If it has a fixed throwout bearing guide tube, with an internal ring inside its tip that reduces the size of the opening, it'll be a '72 or very early '73. If it has a fixed TOB guide tube without an internal ring, it'll be a '73.5 - '75. If it has a removable TOB guide tube, and an early, non-spring-type, clutch cable linkage it's a '76. If it's aluminum it'll be a '77 or later...
If the diff side cover is off, how many teeth on the head of the pinion shaft? 7 teeth = '72-74; 8 teeth = '75>.
Keep the Shiny Side UP!
Pete Z.
Old 12-18-2009, 12:17 PM
cudabnu's Avatar
Great info guys, I'll get the answers soon!
Old 12-18-2009, 12:23 PM
cudabnu's Avatar
Here's what I was sent, looks like it won't work for my needs:
It’s a mag case (filings burned brilliantly), has fixed T.O. bng sleeve, w.o. internal ring, so my best guess would be 1974, maybe '75. 7 Teeth on the pinion (2 are broken off), and the bell housing has a casting number on it, 915 301 101 0
Old 12-18-2009, 03:34 PM
peon77's Avatar
sounds like youre right a late 73 , 74 or 75 ROW. US 75 boxes had an 8 tooth pinion.
75 911s
09 335i 6MT
NVH
Old 12-18-2009, 03:44 PM
cudabnu's Avatar
If anyone is interested he was asking $400 for what he has
Old 12-18-2009, 04:07 PM
