ornas's Avatar
Location: Vilnius Lithuania (it's in Europe and it's not Russia)
Brake fluid question
Hi, I have 1986 930 turbo and on my brake fluid reservoir I have sticker telling to use dot 3 brake fluid only. I have heard that high dot brake fluid is more aggressive and can malt brake hoses for old cars.
What is your experience about this question?
thank you
Old 03-02-2010, 05:43 AM
I think the Dot 3. was the good stuff at the time, there are some issues on the silicone stuff but not std as I know.
Go for the ATE Blue for a street application with some track and you will be fine.
I am dure others willl chime in.
Regards
Old 03-02-2010, 06:07 AM
Bill Verburg's Avatar
thank you
Any DoT 3 or 4 b/f will do fine, use the DoT 4 if you have heat issues otherwise the factory fill ATE type 200(either blue or yellow) is fine
if using DoT 4, prices are all over the place
bang for the buck is Motul RBF600 2 ~ $15/liter, current Cups use Endless RF600 @~$45/liter most expensive is Castrol SRF @ ~$70/liter
Bill Verburg
Old 03-02-2010, 06:09 AM
DOT 3 is not your only brake fluid option. 4 and 5.1 is also acceptable, but complete flush first.
Read up on-line search google
Use this: http://www.meistersatz.com/pentosin/pressreleases/RacingBrakeFluid.pdf About $16 in Cincinnati - $23 on line
1987 Carrera 3.2
Old 03-02-2010, 06:31 AM
ATE Blue or ATE Gold should be just fine for your car. No need to go crazy.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 03-02-2010, 06:37 AM
both wet and dry boiling points are also all over the place, fluid starts to turn wet fairly quickly so i key off that # more than the dry #
ATE Super Blue Racing/ATE TYP 200 DoT 4 536/392
Castrol SRF DoT 4 590/518
Motul Racing 600 DoT 4 585/421
Wilwood EXP600 Plus DoT 4 633/417
Endless RF650 DoT 4 622/424
again if you don't have heat issues you don't need more expensive/exotic b/f
Bill Verburg
Old 03-02-2010, 07:26 AM
