Eye of the Toiger
matty74's Avatar
some 3.6 conversion questions
I am doing a 3.6 engine build and it is going in my 74 but I am going to run PMO ITB's and megasquirt2, 2 x MSD and the stock dizzy.
Now thw MS2 kit comes with a harness, which I will set up myself but I am a bkit unsure about a few other things that I need to do as a part of the conversion.
1. Do I need fly wheel to mate up to the 915? Can I just use a 3.0 flywheel and put the rev sensor on the cam shaft or pully rather than the flywheel.
2. Do I still need a harness engine to car?
3. apart from oil likes etc.. what other conversion bits do I need?
help apprciated
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 12-18-2009, 11:35 AM
Kevin Stewart's Avatar
do a search you will find plenty on this
instant-g.com
also patrick motor sports hes kinda grumpy
you will need a flywheel
not sure on what you got going on the harness
you will need to change some sending units
exhaust is a bit of a hassle
altered cross member search my name i did a post on my 3.6 conversion, Kevin
Old 12-18-2009, 11:55 AM
Eye of the Toiger
matty74's Avatar
exhaust wise I have a set of 1.75 headers and 2in/out muffler.
So I can't just use a stock 3.0 frly wheel and put the sensor on the pulley?
Old 12-18-2009, 12:09 PM
when i changed my fly wheel i remember them looking totaly different, it may have a different bolt pattern. i know i put a 7lb flywheel in and took really heavy wheel out. i have never heard of putting a sensor on a 3.0 flywheel i suppose it could be done seems like a lot of work and a lot time when i lighten fly wheel will help the rotating mass.
big tail pipes LOUD car 2-2.5 lots quiter
Old 12-18-2009, 12:15 PM
Eye of the Toiger
matty74's Avatar
I would'nt put the sensor on the 3.0 flywheel, but on the pulley or camshaft like the clewitt kit
Old 12-18-2009, 12:21 PM
DW SD's Avatar
The 3.6 conversion flywheel has a different bolt pattern on the crankshaft and has the teeth for the flywheel position sensor. Yes, you'd need one compatible with the 915. Several companies sell conversion flywheels.
Jamie Novak told me you can likely program megasquirt to read the flywheel position sensors if you code in the profile of the teeth and tooth count, etc. It doesn't do this out of the box, but needs adaptation. This would seem cheaper not considering hours spent to adding another toothed wheel to the crankshaft. I have no idea how complicated this modification might be.
If it were me, I'd still use the factory engine harness. This would make future removals much simpler. Much of your factory sensors will still be used, as well, like:
temp, oil pressure, alternator connections, starter solenoid, etc.
I think you could probably use much of the factory harness, too. Factory uses connections to injectors, that would still be used.
Things like MAF, Idle air controller would be eliminated. But, other connections would likely be necessary, so maybe you could reuse some of the wiring?
Good luck, should be a fun project!
Doug
1971 RSR - interpretation
Old 12-18-2009, 12:38 PM
Eye of the Toiger
matty74's Avatar
But can I run the rev counter off the pulley rather than the flywheel?
I'm asking this because the caseI have has slight damage being the flywheel sensor mount was broken off, so rather than trying to fix if I can run the sensor of the camshaft or pulley would solve my problem.
Old 12-20-2009, 07:50 PM
i would say no because the pulley is smaller and the eye timing would be off, Kevin
Old 12-20-2009, 08:51 PM
DW SD's Avatar
Sure, you can run the one from Clewett or Smart racing, or a variety of other sources.
Even if you re-mounted the factory one or adapted a new one, it will still take some fabrication.
Plenty of options.
Regardless, you'll need a conversion flywheel. I was thinking it would be cheaper to adapt the factory flywheel sensor since the conversion flywheels will most likely have the teeth for the sensor.
Doug
Old 12-21-2009, 02:27 PM
RETIRED
Joe Bob's Avatar
I wouldn't buy spit from Patrick Motor Sports.
Try Kennedy Engineered for a conversion flywheel....
Old 12-21-2009, 04:10 PM
