CT944's Avatar
Needed: Pic of front fuse panel
I have an '84, and just removed the rediculous aftermarket alarm. There were many extra wires going into the front fuse box, spliced to the ignition as well as a bunch of alarm brains, horns and toggle switches.
All is out, but now the car won't start, so hoping someone can take a good picture of their fuse box so I can be sure I have everything back in place.
Thanks.
2007 997 TT
1992 500e
Old 12-20-2009, 08:39 PM
NineOhOne's Avatar
I think a wiring diagram might help better than a pic.
(Only one I have, sorry...):
Old 12-20-2009, 08:40 PM
2Utes's Avatar
Here is a pic of an 82SC fuse block. The red wire in the upper left was apparently for the PO's stereo power and has been removed. The black cylindrical object in the lower right is a daytime running light module from Daniel Stern Lighting. Other than that it seems to be mostly stock. Hope this helps.
Jeff
'82SC Pacific Blue
'02 C4S Silver (Gone but fondly remembered)
'11 GTS Amethyst
Old 12-21-2009, 08:30 AM
CT944's Avatar
Thanks guys. After removing all of the wires (over 100 feet), the car now starts! Some form of disabler/relay was hooked into the fuel pump fuse.
2007 997 TT
1992 500e
Old 12-21-2009, 02:30 PM
