-   -   "Ex" warning light? (http://forums.pelicanparts.com/porsche-911-technical-forum/518033-ex-warning-light.html)
tazzieman 12-23-2009 03:51 PM
"Ex" warning light?
Tried to find this on the forum but to no avail
Sitting between speedo/tach - occasionally flashes at highway speed.
What is?
http://forums.pelicanparts.com/uploa...1261615884.jpg
billybek 12-23-2009 04:03 PM
That lets you know when your ex-wife is too close to the car....
In my car that lamp indicates when the emission system requires servicing.
Oh Haha 12-23-2009 04:07 PM
[QUOTE=billybek;5086849]That lets you know when your ex-wife is too close to the car....
Awesome answer!!!!!!! I was thinking the same thing.
Oh Haha 12-23-2009 04:10 PM
try this procedure and see if anything changes
http://forums.pelicanparts.com/porsche-911-technical-forum/312992-what-o2-sensor-light.html
TRE Cup 12-23-2009 04:14 PM
interesting- usually we see the same lamp with OXS on it, not EX. Perhaps this was an early version? Anyway if you want to turn it off, you can reset the mileage counter located behind the speedo , that activates this.
you will need a small flashlite, a long shaft, small diameter phillips screwdriver
pry the speedo out from its nacelle
look into the cavity with the flashlite for a rectangular black box with a small round white plug on one end. Push the plug (its really the reset button) with the screwdriver. it takes a fair amount of force. You have now reset the mileage counter. If you want to disable the counter, you will find a round electrical plug connector on the box. Pull that off the box- since its insulated, it won't harm anything dangling, but good idea to wrap it with a lil electrical tape to be sure.
Reinsert speedo and enjoy no more lamp, or light clicking sound coming from your dash
80-911SC 12-23-2009 04:28 PM
i remember seeing somewhere here that that light is the O2 sensor light , could be wrong though ... mine has one but doesn't have the EX on it and ive never seen it blip
tazzieman 12-23-2009 05:14 PM
911 is ex Japan ; has catalytic c which we didnt have in Oz back then(78). Some sort of sensor screws into the exhaust but its end has been crimped and there is no cable.
The pretty Christmas light doesn't bother me and I thought it meant my driving was bordering on "excellent" or something. Now I need to improve so it stays on all the time!
tony9704 12-23-2009 05:18 PM
Well put taz.
MrScott 12-30-2009 08:00 AM
I'd been trying to track down that clicking for months - no o2 sensor so no light. Disconnecting the counter solved it. Thanks!
