Are these the correct struts and housings for my 72 T?
Pict below. Sorry, do not have part numbers (yet).
![]() TIA, Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs |
It depends on whether or not you want to stick w/ the stock M calipers or not. If it were my car I'd want to switch to A or S calipers and Bilstein struts.
The difference between the M struts and A/S struts is the caliper mounts, 3" for M and 3.5" for A/S The part # for the '73 S/Carrera A/S Bilstein strut is 911.341.041.33 /L and .042.33 /R
Plan on keeping the brakes as is (I think the M stock ones are still on there).
Scott
Then you probably only need the Boge inserts, unless the strut itself is damaged
