84-89 Carrera lightweight bumper replacements?
I'm hoping someone can recommend make & vendor for lightweight front & rear bumper replacements for my '84 Carrera. I want to start dumping some weight. Seats are also on my mind.
![]() The only model I've been able to find online so far is an IROC-style affair with wide body fender flares and provision for front oil cooler. I don't have the budget to do a big front oil cooler or a wide body conversion. I'm looking for a set that will replace the stock heavies and accommodate the Dansk 2-out exhaust with a minimum of modification. Cheers
~Hugh '84 Carrera |
Ahhh, thanks. I like the rear bumper designs. The fronts for 74-89, though, are either the Yellowbird design (oil cooler again, and changes the lines to look like a bullfrog) or that glass reskin of one piece of the existing metal bumper, which I assume would not lose the heavy shocks and aluminum spoiler.
Any more stuff out there? Thanks!
~Hugh '84 Carrera |
I think Rennspeed has a stock replacement. Other than stock there aren't many other non-oil cooler options.
I got mine from Dave at TRE motorsports. nice fit and finish. narrow body RSR style.
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
leave the cooler opening close , as the gold car above illustrates.
That way you get more downforce too
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Thes any good Jhugh?
Ultra-light and easy to fit. Can accomodate twin out too. Hope this helps. ![]() ![]() Regards Jammo.
O2 In Sully We Believe |
I used fiberglass bumpers from Getty Design. They are exact replicas of the stock bumpers. Nice piece of kit.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
I have BW Motorsport Yellowbird replicas. No oil cooler in the nose (yet) and just cut a plate to block off the opening to increase downforce. Well made with good fit and finish. But I need more downforce so I may be going to the same TRE front piece as Scotitude. I prefer the Yellowbird look but need the splitters of the TRE piece.
You can see the gray aluminum plate in the cooler opening:
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Sorry - the manufacturers are Clubautosport and are based here in the West Midlands, UK. However, they make products for several companies and ship too. Good quality, good fit and with the minimum of prep. Very light too. Hope it helps. Regards Jammo.
porsher
Here's the front bumper on my car.
Fit and finish is great. Remember you are dealing with FRP so additional final finish is required and you will need to fabricate your own mounting brackets. Front aperture is glassed over so you can leave it closed or cut it out.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car Last edited by aston@ultrasw.c; 12-28-2009 at 08:12 PM.. |
