Almost Banned Once
sc_rufctr's Avatar
Here comes the Tricky bit...
I recently removed my engine and trans from my car...
This is itself is not the "tricky bit"... As many people here drop their own engines/trans.
But to undo the oil line next to the end of the cooler I used two spanners and a hand clamp.
I had always struggled with this in the past and because of a slight injury to my shoulder I couldn't do it the conventional way.
As I sat there thinking about a solution I saw a hand clamp used for carpentry sitting on my bench.
I place the two spanners on the flats and adjusted them so I could squeeze then together using the hand clamp. The nuts loosened with no drams and minimal stress to the lines.
After I finished I sat back and felt a bit foolish as to how easy it was compared to the conventional way...
Anyway... I'm sure it's something that you may be able to adopt on your next engine/trans drop to make it a bit easier.
I'm probably not the first person to do this but I think it's worth sharing.
I plan on tightening this joint using the same method but with the spanners reversed.
Does anybody else have a "custom" like solution for doing otherwise difficult tasks on their cars?
What about custom made tools???
The nut in question...
The set-up...
A better view of the clamp...
- Peter
Old 12-17-2009, 05:48 PM
steely's Avatar
I don't have any custom tools that I can think of off hand, and I do rely on breaker bars if I can fit their length in. This idea makes sense, and my hat is off to you for not letting an injury stop or slow you down.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-17-2009, 09:05 PM
disband
juanbenae's Avatar
check out the brain on this dude! well played sir.
Old 12-17-2009, 09:12 PM
disband
juanbenae's Avatar
by the way,, was the mrs. impressed? i suspect not, & dam her for it..
Old 12-17-2009, 09:14 PM
Almost Banned Once
sc_rufctr's Avatar
I don't have a misses. Just me and my kids. (long boring story)
My mum was impressed. Does that count?... haha
- Peter
Old 12-17-2009, 09:36 PM
disband
juanbenae's Avatar
it counts immensely! ive plenty of gals, but only one mum.
cheers
Old 12-17-2009, 09:54 PM
haycait911's Avatar
now that's a bit of original thinking. I like it, very controlled compared to the usual method. I will implement the next time around.
I'm tempted to buy a couple of cheap wrenches, cut off the box ends, and weld on some flat plates to clamp against. Don.
Old 12-18-2009, 01:03 AM
nineball's Avatar
that's what i did but instead of welding i took a couple pieces of pipe and bent the ends in to the middle a little with a hammer to fit on the wrench handle better. it serves the same end result but is much easie to fit into the toolbox.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 12-18-2009, 06:04 AM
Almost Banned Once
sc_rufctr's Avatar
Any more tricky bits?
- Peter
Old 12-29-2009, 06:25 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
The set-up...
You have earned yourself a case of Crown Lager........
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-30-2009, 07:38 AM
sancho
sancho's Avatar
well done Peter, good to see alternative ways to do things....especially with your injury and all
1980 SC targa blue-SOLD
1986 Carrera wide body white
Old 12-30-2009, 07:41 AM
175K911's Avatar
Very nicely done. I just dropped my engine and trans and never thought of that (bad shoulder here too). I have a half dozen of those same clamps sitting on my table saw and use them to press back brake calipers too. But in my case I used my long channel locks to clamp the two wrenches together, though I much prefer your idea. One more use for the old clamps.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 12-30-2009, 07:43 AM
