Poll: Buy a NEW motor, or get another Used one?
Poll Options
scotricker's Avatar
Should I buy a NEW heater blower motor? Or is another used one an OK idea?
I'm having angst and a big dilemma... buy Another used blower motor, or just bite the bullet and get a new moto from our host. It's not all that expensive,,, but I'm stalling on making a decision here
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 12-03-2009, 11:24 AM
mca mca is offline
mca's Avatar
How about backdate heat as an option? Might be a bit more expensive but it really cleans up the look of the engine bay. Well worth it in my opinion.
I'd give you my motor but it is being stored in a POD right now b/c I am between homes.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 12-03-2009, 11:27 AM
MattKellett's Avatar
I voted to just buy a new one. $120 and it's done - there's no way to know if a used one will last 2 days after you install it.
Matt Kellett
87 Carrera Coupe - Marine Blue
60 MGA - Chariot Red
66 Jaguar MKII - Sherwood Green
09 VW GTI - Candy White
Old 12-03-2009, 11:32 AM
DCinVA's Avatar
Buy a new one, install it, and then don't worry about it for another 30 years !
Dave
2014 Cayman S (Awesome car!)
1991 911 Carerra (Semi Refined fun)
1986 911 Carrerra (Raw fun) sold
2001 Boxster S (Refined fun) sold
Old 12-03-2009, 11:41 AM
mca mca is offline
mca's Avatar
pelican classifieds - heat ducts
This guy is selling the two outlets for $120 + shipping. In the event that you decide to backdate.
Old 12-03-2009, 12:18 PM
pete3799's Avatar
If it was me i'd pull the old one, get all the dimensions from it, and go to NAPA
and order one that will work for about 35.00.
I haven't replaced the engine mounted blower yet but i have the fresh air one.
Pete
79 911SC RoW
Old 12-03-2009, 12:23 PM
Broke
Westy's Avatar
Would taking it to an electrical shop and having them rebuild it with new and modern materials be an option???
Beer is proof that God loves us and wants us to be happy. B. Franklin
93 968 Cab
81 SC Targa (Princess) Now Residing in Denmark
1973 RS Z28 Vash will never own it!
Old 12-03-2009, 12:37 PM
scotricker's Avatar
I read through the backdate posts, and I don't think I want to do all that right now.
I could pay a guy to try to fix the motor, but that would 40-50 bucks at least, anyway...
Or do I just buy me a new motor from Pelican parts?
Or find a really really good used one?
Scot
Old 12-03-2009, 02:43 PM
muck-raker
kidrock's Avatar
dude, bust out the bucks for a new one. You'll kick yourself if you get a used one that lasts for a year or 2.
And if you ever decide to backdate, your blower assembly will be worth more $$$ if you decide to sell it.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 12-03-2009, 03:38 PM
steely's Avatar
Not to hijack the thread, but what does backdating do for you, give you forced hot air off the engine blower?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-03-2009, 04:18 PM
Walt Fricke's Avatar
Dan - you got it. Early 911s didn't have a blower motor. Came in maybe '74? Guys with the older cars have told me they have plenty of heat, but I'd not give up my blower motor.
Scott - Search for "heater blower" or something similar to pull up posts on how to replace the cheap and not all that durable Bosch motor with something much better and not expensive. It is a common topic. The Bosch is not rebuildable. You can take it apart (some of them, anyway) and maybe replace brushes. But it is the bearings that go. I've tried lubricating them, but without real success.
When the "used but still good" replacement I have starts screeching, I'll hunt up those posts and put in the better motor.
Walt Fricke
Old 12-03-2009, 06:28 PM
I just unplugged my blower motor. The heat acts like the backdated version; the engine fan is the 'blowerfan'.
Works great as long as you are not idling in zero degree weather. Need engine revs for the 'blower fan'.
Even in 20 degree weather, on a run, I have to push the levers back down; gets too hot.
Old 12-03-2009, 08:07 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
[post deleted for promoting a competitor]
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 12-04-2009, 09:33 AM
Eric
Pelican sells the same part.
Pelican Parts - Product Information: 911-624-151-02-PH)
Like you, I also like to use our host first and normally even if they don't show the item in their catalog, they can still supply the part.
Matt Kellett
Old 12-04-2009, 09:47 AM
scotricker's Avatar
well,, after all this discussion, I opted for a used one again. It's on the way.
I will post and let you know how it works. If this one dies, I'm gonna get the new one from Pelican.
Scot
Old 12-04-2009, 11:25 AM
aircooled911's Avatar
Hey Scot,
had a squeaky heater blower motor as well. Opted to pull the assembly--easy--and disassemble. Pulled the motor and squirel cage out of the assembly. There shouild be a little in and out play on the motor shaft--mine was tight.
Then removed the s-cage from the motor and shot a little lube at where the shaft enters the motor housing. after a little spinning and pulling of the shaft it seemed to free up a little. Reassembled and the squirels are no longer screaching for now.
Shaft play may have been the culprit. Visual on the brushes looked ok
Will probably just order the replacement motor listed above down the road and be done with it. Mine is a 77-911S with 190k on the clock.
It's been very cold here lately so will be happy to have good heat without the sound effects.
Cheers, Jim
Jim
1995 993 cab. Baltic Blue - M030 - Fabspeed - RUF
1977 911S Targa - yellow - back to the fatherland
1976 Alfa GTV oxidized away
Old 12-30-2009, 10:49 AM
Head416's Avatar
Heater backdate looks better. No blower to go out in the future. My backdated heat cooks my feet and I have to turn it off... gives me all the heat I need and more.
Aaron
'81 911SC RoW Targa
Old 12-30-2009, 10:53 AM
Dixie Region R Gruppe
w21055's Avatar
amen to that.
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 12-30-2009, 11:29 AM
