dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
Door switch/warning buzzer diode?
Can anyone tell me the location of this diode?
Car is an '87 3.2.
I'm troubleshooting electrical gremlins. I know it is unusual, but diodes can fail to a short (rather than the more common failure to an open condition) and that might explain some issues.
Thanks in advance.
Old 05-28-2021, 06:47 PM
Yes, It is in the frunk and not easy to get to....
The Warning relay is behind oil temp and fuel level instrument gauges. The diode is about 12-15 inches down the harness that connects to the relay. You should be able to get to it from the frunk
The reason I know this is because I had to repair the front harness and have attached a picture showing the relay socket and the diode for you. The large circle is the diode, the small circle is the relay socket
I don't have a clear picture of the diode and socket "in place" to show you....but you should bee able to find it from here.
Good hunting...
Old 05-29-2021, 07:14 AM
I did find a better picture showing the location of the warning relay/buzzer diode.
Its behind the brake master cylinder...see the pic.
Al
Old 05-29-2021, 08:09 AM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Thumbs up
The information & photos you provided were a big help - Thanks!
Fyi, I discovered this is one of the infamous 911.617.108.00 diodes.
Old 05-29-2021, 12:26 PM
