Oil Pressure Sedning Unit Generic Replacement
The Porsche VDO pressure sender is disgustingly pricey and not readily available due to the odd thread size. You can buy the same sending unit (0-5 bar) with a different thread for <$30 at various places online (eguages.com for one).
So I took mine, cut the can off, carefully ground the remaining nut flat, and drilled & tapped it for an M10x1.0. They sell 1/8 NPT senders also, but I had the M10 tap sitting around, and I like the sealing washer concept. I did have to change the electrical connector to a screw eye. I'm actually surprised Wayne doesn't sell the aftermarket units and a bushing as an option. At any rate, it works fine, and I have an extra low pressure contact that I won't use. For some reason, the sender with the low pressure contact was cheaper than the one for just the guage.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
creative
Ed M 86' Coupe |
Northern Motorhead
Think Wayne sells two different models.
I ordered the OEM unit at $78.00 dollars for my 89 911 and Pelican also sells a cheaper "non OEM" unit for something like $45.00 dollars. Funny thing is my oil pressure gauge was pegged out at 4000 rpms as of last week and my car just got back from a three day DE and the stupid gauge is working now ... go figure ... New sender unit is on the way from Pelican but i will change it regardless ! As Ed says,pretty ingenious fix indeed ![]() Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 Last edited by wildcat077; 08-21-2011 at 06:19 PM.. |
Very ingenious.
My .02--- If at sometime you have the line off, have someone tig weld the fitting into the line. One less chance for a leak.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
I have a non-OEM sender (URO, add umlaut to the U), and it keeps making the pressure guage fluctuate wildly between 4 and 5 bar when the engine gets hot ... and it's less than 1 year old.
Schleprock
Nice job Frank. Very smart idea to make a coupler out of the old sender base.
Kevin L '86 Carrera "Larry" |
