e3photo's Avatar
Uneven hood on 88
I did a search, but did not find an answer. I have an 88 coupe, and the gaps on the hood look good, but the left rear corner sits a bit high. There seems to be a bracket with 3 bolts the the hinge is connected too, and the first impulse would be to loosen the bolts, and try and bump the corner down a tad. Am I on the right track, or am I missing something.
It is the little things that will drive you crazy.
Cheers,
Emerald
'88 911 coupe, Laguna Green Metallic (sold)95 993 Aventurine Green(sold)
97 993 C4S Vesuvius
Old 01-04-2010, 06:47 PM
Banned
Be careful. That hood is heavy.
Old 01-04-2010, 06:49 PM
e3photo's Avatar
Thanks, I'll be careful. It is easy to forget about the weight because the hood shocks make it seem light.
Cheers,
Emerald
97 993 C4S Vesuvius
Old 01-04-2010, 06:57 PM
rw7810's Avatar
you're on track. The hood hinges are adjustable to do exactly what you have in mind.
Robert Williams
70' 911T
Old 01-04-2010, 07:03 PM
e3photo's Avatar
Thanks Bob,
I think I'll have a go at in the next couple of days. I will be sure and take it slow.
Cheers,
Emerald
97 993 C4S Vesuvius
Old 01-04-2010, 07:13 PM
Lightbulb
Use painters tape around the edges when doing adjustments to avoid marring the paint.
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-04-2010, 11:15 PM
Banned
Remove the shocks first.
Old 01-05-2010, 07:23 AM
