another unknown reservoir
Under the left fender on my '85 Carrera there is a reservoir located over the main one and linked to it by the same bolt witch fasten both to the body.
The shape of this little plastic tank remind that of the intensive washer's one but it is not under the boot but, I repeat, under the left fender and again there is no switch on the right side under the instruments.
Does anyone knows what is it?
Thank you very much!!
Old 01-06-2010, 03:26 AM
Turboo934's Avatar
Catch tank for for the gas tank.
Robert. 1976 930/934 Turbo Carrera RRS, Cristine She can be evil but oooh so much fun
Old 01-06-2010, 04:41 AM
Somatic Negative Optimist
Gunter's Avatar
The small line on it deteriorates over the years and leaks fuel. Replace if needed.
The area under the left fender is very prone to rust and it's rust right through to the battery area. It is recommended to remove the evaporator/overflow tank and the washer tank to clean out all the mud and gunk and then repair if necessary with rust paint.
You'll be glad you did.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-06-2010, 08:08 AM
Thank you very much: now the whole thing is clear!
Old 01-08-2010, 02:12 AM
85Shark's Avatar
Agreed, I recently did a A/C delete and was amazed at how much road gunk came out with the lines. So while under the left fender I did just that pull the two tanks gas/washer fluid and sure enough more road gunk up in there also you will be glad you cleaned it out.
Drew
86 911 Targa
85 928S (Sold)
Give me my dam coffee, I can sleep when I'm dead!
Old 01-08-2010, 04:46 AM
