Convert Targa To Coupe
Is it possible to remove the targa bar and the targa parts around the windshield area, and install a complete coupe donor roof? Has anyone done this.
I have removed complete roofs from 911's and installed donor roofs with no problems.
Old 01-06-2010, 03:49 PM
Formerly known as Syzygy
Canada Kev's Avatar
Seems kinda like not worth the effort, even it it was possible.
You would also need to add door glass frames and such. And probably a bunch of interior pieces and a million other things that don't immediately come to mind.
Kevin
Old 01-06-2010, 04:36 PM
Paul K's Avatar
Vapors:
There have been some commercially built units to convert a cab into a coupe, so they should be fittable, as the targa & cab have the same body. And I think someone here made one.
Maybe do a search and see what turns up?
Good luck!
Paul.
Edit:
1976 Targa to Coupe
http://rennlight.com/hardtop/
Targa to Coupe Roof Conversion
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 01-06-2010, 05:59 PM
just sell it and buy a coupe. I've seen posts here of people who have done it though.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 01-06-2010, 06:07 PM
80-911SC's Avatar
why not make the targa to a speedster ?????? if for the track add a bar or xcross bracing for street stability ........ JMO
stev
Old 01-06-2010, 06:19 PM
I agree......probably better to just buy a coupe instead of going through all of the work to convert.
Old 01-06-2010, 06:30 PM
Almost Banned Once
sc_rufctr's Avatar
Converting a Targa to a convertible is pretty straight forward.
I even remember seeing a Porsche technical bulletin on how to do this.
To go from a Traga to a coupe would require way more parts and time.
It's doable but you should ask your self why.
Wouldn't it be easier to make sure your Targa roof is adjusted and fitted properly and enjoy the car.
Often owners are swayed by the opinion of others about their cars.
The Targa is a great car. Don't let anybody else tell you otherwise.
- Peter
Old 01-06-2010, 06:31 PM
group911@aol.co's Avatar
It's fairly easy. Contact Cory at Planet 9 Eleven. He's done them before.
Thanks,
Bob
group911@aol.com
Old 01-06-2010, 07:07 PM
I was debating this a little while back. I ended up buying a 74 NSR Coupe tub to just swap my parts over too. It will take a lot of wrenching, but I know everything is going to line up when its done. But, if I was building a track car, I would pull off the targa parts, build a full cage, and put on a fiberglass roof. However, if you are familiar with bodywork, and you have a good donar to get all the metal you need, I don't see why you couldn't do the swap yourself.
1984 Porsche 911 Targa
1974 Porsche 911 Coupe- just a tub... for now
Old 01-07-2010, 10:47 AM
I remember watching a Targa to Cabriolet conversion done at a Tweeks Porsche event in Illinois the summer I met Rarely L8. They did it in just a few hours with their "engineered" kit. However, those conversions never seemed really right even with all their professional knowledge.
I keep my Targa in the garage with the roof off and ready for those fine days and drive the coupe when its too hot, or too cold, or likely to rain.
Dan
Old 01-07-2010, 12:28 PM
3 restos WIP = psycho
kenikh's Avatar
It has been done a lot - it is typically on race cars to take advantage of the stiffer chassis in conjunction with a solid roof.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-07-2010, 04:10 PM
Easily Confused
dtxscott's Avatar
Yep, Herbie was done this way. He's a cool car.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 01-07-2010, 06:12 PM
