265/16's came today, Kumho XS's
Got my 265/45/16's and 225 Kuhmo XS's today.
Wow they are wide and sticky. Pics of my 225 Star Specs and the 265 XS's. ![]() ![]()
let us know how the kumho's are...i had the mx's but i think they are now discontinued
Who is selling the 225's and what is the profile ? are they 225/50s ?
Are you putting the 265s on a 9" wheel?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
...and pics on the car, please. I'll be curious to hear about clearance issues too.
I have the same size Kumhos and while they are only 45's, being 265mm wide they still have hefty sidewalls... |
hey, looks like you ran over a dollar!
1988 porsche 911 "CE" cabriolet |
As a test, I'd tried a set of 265/40-17 (same height as a 265/45-16) on my 911. Wasn't even close, too tall and hit the fenders. If I'd driven on them I'd have burned the paint on the fender flare about 2" above the fender lip.
correct 245/45-16 is about 24.8" tall the 265/45-16 is about 25.4" tall Taller and wider is a bad combination
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Update please,
I would like to know if these tires worked on a carrera. Thanks. |
yes update, will these fit under carrera guards. some pics would be nice
I was ready to pull the trigger on this size as well for my 10x16's but I was concerned about the overall diam. (25.4") specially with euro height. I'm running 245/45 now and it's fine but wanted a wider footprint. I'll wait for the update from the OP.......
1984 911 M491 2006 997 2008 955 GTS |
I have 275/40-17s on the rear of an SC flared car and they fit fine on 9x17 wheels...
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I have a set of these on my Carrera 3 (215/50x16 and 225/50 x16).
So far I have found them to be excellent for both wet and dry grip. Probably not up to "R" compound levels of grip in the dry, but they do give a very nice, gradual transition from grip to slip. The only thing on the negative side is that the transition to slip does feel just slightly 'numb' to a degree. Given their price and performance, I don't think you can go wrong.
Sheldon '92 964 Carrera 2 (Manual) '07 BMW 335i '76 911 Carrera 3.0 (Gone, but not forgotten) "Give me ambiguity or give me something else!" |
Before I go to 17's I would like to give these a try. It seems like they should fit, but I'm a little worried about the height.
I'm talking the 265/45 on 9's. Or I'm looking at streching 225's on 9's, not sure if thats a good idea.
I ended up going with Mich Pilot Sport Cup race tires.
Remember the stock tire height on a 911 is closer to 25". 245's are a little shorter. 265's are a little taller. You can easily put 245's on a car set up for stock 225/16's but stepping up to 265's will probably require some adjustment to ride height, camber, and rolling fenders. I suspect it is going to be a closer fit trying to get 225's on the front than the 265's on stock Fuchs 9's in the rear. One board member ran the Kumno V710 265's which are wider still on 10" rims with the proper set up. Also, a lot of the PCA club racers run 245/275's with proper set up on stock bodied 3.2's and SC's. It is getting hard to find tires for a 9x16 Fuchs. Toyo makes a solid selection of 245's for them and they are great tires. They should even have the RA1's back soon if not already out. Also, the Dunlop Z1 225 is supposed to be rated for a 9" rim. |
Kumho xs
i am installing a new set of these tires on my early widebody conversion. 315/30/18s and 235/40/18s . on 3.6 rh rims. looks great...waiting for an early turbo set of spacers for proper fitment. diameter seems right on the money. price is way right for these tires, not great in the rain. (dont see much of it in socal) . update when theyre on the road. kevin
sudo apt-get purge 930
That's what I have on my 8's and 10's. I love them. Very sticky.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
