-   -   Looking for replacement parts for a Bosch injector tester (http://forums.pelicanparts.com/porsche-911-technical-forum/520401-looking-replacement-parts-bosch-injector-tester.html)
LM3929 01-08-2010 12:31 PM
Does anyone have a source for the glass or plastic reservoir on an older Bosch injector tester?
I have one that is missing the reservoir?
Thanks Lorne M.
john walker's workshop 01-08-2010 02:27 PM
i got one through worldpac. see if pelican can round one up for you.
LM3929 01-08-2010 02:56 PM
Thanks John, I have a Worldpac near me so I will try them first.
Lorne M.
Grady Clay 01-08-2010 02:59 PM
John,
Do you have part numbers and an exploded diagram?
Mine is still complete and functional after 40+ years of use (new in 1969) but it could stand some attention.
Do you know a P/N for the test oil?
Available from Worldpac/Pelican?
Best,
Grady
jcge 01-10-2010 01:12 PM
Although not from the MFI tester, this might be useful - from the K-Jetronic injector tester (CIS)
Fluid container & Seals - 0 986 615 331
Valve Body Seal Kit - 0 986 615 335
Might be common parts
John
LM3929 01-11-2010 01:48 PM
Anyone have part numbers and an exploded diagram of the tester?
Thanks Lorne M.
john walker's workshop 01-11-2010 02:30 PM
for fluid, i use mineral spirits. alternative numbers are KDJEP400-1 (bowl), and KDJEP400-10 (seal kit).
LM3929 01-26-2010 11:52 AM
John, sorry to a pain but are those part #s from worldpac?
Thanks Lorne M.
Vin-barrett 01-26-2010 03:16 PM
those look like Bosch #'s
subscribed, i need parts for mine too....
LM3929 01-29-2010 03:55 PM
Tried Pelican and no luck worldpac shows no listing either I will try Fleabay next
LM3929 02-20-2010 11:11 PM
bump
al lkosmal 02-21-2010 08:32 AM
Diesel Injector Tester Mercedes 190D 240D 300D 300SD : eBay Motors (item 380179211702 end time Mar-18-10 11:46:44 PDT)
Lorne,
I bought one of these. This is sold by a company that specializes in Mercedes, but the injector fitting is good for MFI injectors. I'm not familiar with the older Bosch testers, but perhaps the reservoir is similar enough to work for you.
PS: I see that you are in the PNW. This company is located in Bellingham, WA.
LM3929 02-22-2010 10:50 AM
Thanks Al, I have have no luck so far trying to find the parts but theirs look like it might work I will give them a Call today and check them out.
Thanks again
Yes I'm about 35/40 minutes away from Bellingham.
Vin-barrett 02-22-2010 11:37 AM
These testers seem to take a bunch of different shapes.
Here is my mercedes diesel injector tester that im looking to freshen up to work with CIS injectors.
Lorne
I looked at the reservoir and unfortunately there are no part numbers on it.
http://forums.pelicanparts.com/uploa...1266867451.jpg
LM3929 03-05-2010 04:00 PM
Still looking, Als info didn't pan out
LM3929 04-07-2010 05:13 PM
Still looking for a fuel reserve bowl any ideas?
Lorne m.
rsscotty 04-08-2010 05:39 PM
I sent an email to Bosch asking about the resovoir availability and they replied...
Please contact our hotline at 1-800-521-5462. They should be able to assist you.
Just give them the Bosch part # for Fluid container & Seals - 0 986 615 331
Hope this works out.
LM3929 04-08-2010 05:50 PM
Thanks, those are the numbers that I have been looking for, I will call them in the morning.
Thanks again Lorne M.
rsscotty 04-08-2010 06:07 PM
Let me know what they say!!
LM3929 04-22-2010 11:42 AM
Getting closer.
They gave me another number, who gave me another number but they didn't specal order parts so back again to Bosch and well I have another number who told me were to go.. nicely and lets see where this lead goes.
After all this I hope the container works as the tester I have is the really old version with the two guage setup but the parts look doable.
Thank again Lorne M.
