1997 993 Stalling Issue
Recently, after driving long enough to warm the car up, it will start stalling when I come to a stop. There are no problems when cold and I recently cleaned the ISV - which needed it badly. Other than the stalling the car runs strong and as you would expect.
Any ideas?
Old 02-20-2010, 10:06 AM
Hi,
How old are the oxysensors?
With a clean and functioning ISV, these do not stall unless there are some vacuum leaks, old primary oxysensors, etc.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-20-2010, 10:55 AM
Paul K's Avatar
Have you disconnected the battery recently?
If so, it will take a while for your car to 'reset' itself.
If that's the case, the only fix is driving it.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 02-20-2010, 05:49 PM
Thanks for the ideas. I have not disconnected the battery. I will look for vacuum leaks and check out the O2 sensors.
Old 02-20-2010, 08:55 PM
