-   -   weber carb setup stupid questions (http://forums.pelicanparts.com/porsche-911-technical-forum/520764-weber-carb-setup-stupid-questions.html)
Emery G. 01-10-2010 04:20 PM
what is the best way to setup the fule lines? do i need to run a return line? is it better to run the carbs in series? how bout a pressure regulator? I am setting thes up for my 914_6 project. and i want to replace the fule lines...:confused:
James Brown 01-10-2010 04:38 PM
Did you try the 914 board?
Steve@Rennsport 01-10-2010 05:15 PM
Emery,
Carburetor installations like return lines, ala 914/6, which really helps prevent vapor lock in hot weather.
A pressure regulator is mandatory for Webers as they MUST have 3.5 psi.
Carbs are fed in parallel from the FPR,....again, look at pics of the 914/6 as a general example.
Emery G. 01-10-2010 06:13 PM
Thanks steve for the input.
Quickstep192 01-10-2010 07:21 PM
I set mine up using a spin-on fuel filter for a boat. It has multiple connections, with two outputs, allowing me to use one for each carb. I come into the filter from the tank and use the other input for the return with a valve in it to constrict flow back to the return, thus regulating the pressure to the carbs. I put a gauge between the filter and the valve so you can see what the pressure to the carbs is. Then, I take one of each of the outputs to each of the carbs. I though it made for a nice neat installation. By the way, if you adopt this, don't use the filter with the plastic bowl. Here's a diagramhttp://forums.pelicanparts.com/uploa...1263180099.jpg
