nineball's Avatar
lift question
does anyone by chance know the length between the front and rear lift points? i may have found an older scissor lift but it does not have adjustable arms, rather just large lift areas. i am trying to find out if it will work or not before i go to look at it tomorrow.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 01-13-2010, 09:54 PM
nineball's Avatar
anyone? kinda need to act quickly on this.
Old 01-14-2010, 12:57 PM
Max Sluiter
Flieger's Avatar
here is a free bump
Old 01-14-2010, 02:16 PM
nineball's Avatar
thanks. i am looking for the distance between points C and D if anyone knows them.
Old 01-14-2010, 02:37 PM
aj88cab's Avatar
Something like this?
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 01-14-2010, 03:17 PM
nineball's Avatar
thanks but i don't think i am reading that right. if i were to subtract D from C to get the difference it comes out to 350mm, or 13.8 inches, which i know can't be right. this is the lift i am going to look at tomorrow (too late for tonight) and as you can see there are no moving arms just the 2 platforms.
i was thinking that if it is long enough i could just use some small wood blocks on top of the platforms for lifting the 911 but without knowing the length under the car between lift points i am dead in the water.
Old 01-14-2010, 03:29 PM
aj88cab's Avatar
That would be about 6.5" on each side. Sounds about right to me. The "D" points are the rear jack pad locations on a Carrera, not sure how that would relate to your SC.
Old 01-14-2010, 03:33 PM
Max Sluiter
Flieger's Avatar
You want the measurement from the front to the rear jacking points, correct?
C and D are widths.
M is the distance between the front and rear jack points (C and D)
1215mm
Old 01-14-2010, 03:36 PM
nineball's Avatar
C and D are widths.
1215mm
thank you! 47.8". now i just hope the lift is near that length.
Old 01-14-2010, 05:51 PM
